Linksys WRT54G2 Wireless Router Logo
Posted on Jul 08, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
WRT54G2 wired desktop fine, can't connect to wireless.
WRT54G2 functioning, looks to be broadcasting but no wireless devices can connect. Re-started several times, changed password but no joy. Ipod & wireless notebook cannot connect, desktop that is wired through the router is connecting fine & wireless devices detect signal but cannot join even with correct password. Thoughts?
Anonymous
Level 2:
Novelist:
  • Expert 109 Answers
  • Posted on Jul 09, 2010
Anonymous
Expert
Level 2:
Novelist:
Answers
109
Questions
0
Helped
53604
Points
315
Hi Seth6025,
Try without using Wireless Encryption (password).
Try changing channels; default is 6; try 1 or 11.
Change your SSID: personalize it
SSID broadcast: Enable
Check the advanced wireless settings and make sure MAC filtering - DISABLED.
Reset the Linksys router by pressing RESET for 30 seconds should everything fails and re-configure. Firmware is another consideration BUT this is just a new release.
Regards,
Angel
  • Anonymous Sep 30, 2012
    This worked for me : Try changing channels; default is 6; try 1 or 11. I had channel 11 out of 13, and moved to number 10 and then connection was succesful; then I changed it back to 11 and works like a charm. Thank you for your solution.
Show me how to connect linksys wireless
Hi
The Router configuration is not that much difficult, only few thing you have sure,
1) Correct ADSL Connection User name & password,
2) Chose unique ip address in All host.
Follow the mention bellow instruction to configure and connect to Wifi Router,
  • Plug the network cable ( Mine was Blue ) which comes with the Router Box pack to your computer. The other end goes into any of the Router Ethernet Port ( 1 or 2 or 3 or 4 )
  • Now type in 192.168.1.1 in IE or Firefox or any browser. You will prompted for password which is admin. You must be logged into Linksys Router.
  • Now since your ADSL modem is also having the same IP , we will change the IP address for WRT54G2 Router to 192.168.5.1
  • Under Setup >Basic Setup look for Network Setup and Change Router IP. Change to 192.168.5.1 and Save changes.
  • Since the IP has changed you will need to close the Browser.
  • Sometimes the IP doesnt change automatically. Do a IPCONFIG / RELEASE and then IPCONFIG / Renew
Making WRT54G2 Router talk to ADSL broadband modem
  • Plugin the Ethernet cable which comes from the Modem into the port on Wrt54g2 router which says Internet.
  • Open Internet Explorer and Type in 192.168.5.1.
  • Type in same password ( admin )
  • You will be in Setup > Basic Setup
  • Take a look at Section , Internet Setup. The current selection should be Automatic Configuration DHCP. Select Static IP instead.
  • Add following details to it. In the first step we backed up All the IP configuration. Use them here
Internet IP Address: . . .
Subnet Mask: . . .
Gateway: . . .
Static DNS 1: . . .
Static DNS 2: . . .
Static DNS 3:
ADSL Modem Settings to Wrt54g2 Router
  • Once Done just save changes and you should be back at same page.
  • Now try to connect any application which talks to internet. You should be able to connect
Configuring for Wireless Connection :Now once your Router is talking with Modem, it is pretty easy to connect on Wireless. The only thing we need to setup here is Security. Lets get WIFI
  • Get to the Lynksys page again. Do all login and regualr stuff.
  • Now look for menu Wireless, click on it. You should land on Basic Wireless Settings.
  • Select wireless configuration to Manual .
  • Wireless network mode to Mixed.
  • Give a Wireless Network Name (SSID), make sure its unique.
  • Make Wireless channel selection 11 ( 11 - 2.463 GHZ)
  • Select Wireless SSID Broadcast to Enable
  • Save Settings and you will be back at the same page with changes you made.
Now Lets secure the Router :
  • Go to Wireless Security on the same page.
  • You will need to configure here Security Mode : WPA Personal, WPA Algorithms: TKIP
  • WPA Shared Key is what you will need when you connect to your router without wire. This key does the authentication and keep unwanted people away. Add 8 digit alphanumeric key.
  • As suggested in comments, there is a new mode which you can use : WPA2 with AES
  • Save changes.Just make sure you save that key to a notepad or remember it.
Wrt54g2 wireless security
  • Now last step, Move to next menu Security > Firewall .
  • Uncheck Block Anonymous Internet Requests .
  • Save Settings.
Wrt54g2 firewall settings
  • Remove the blue cable which you had connected with Router.
That's it. Now just turn on your WIFI and Search for the router. The name should be visible. Click to connect. At this stage it will ask you for the Password or Shared Key which we configures just above. It will connect and you will be able to connect to Internet.
That's all Folks. This is how you connect WRT54G2 Linksys router with Adsl Broadband Modem. If you have any questions feel free to comment.
Linksys WRT54G2 Wireless router unable to connect to Internet
Try again by Disabling the WEP (or WPA), MAC Address Filtering and Firewall Setting Individually. Should be a problem with one of those. Then when you receive the Signals, try to Adjust using Bottom Up method. That means one setting at a time, Hardening the Security. Have you checked your DNS settings? Have you checked the Channels you are using? Re check them and try again.
Feel free to contact back.
Please rate the answer if it helps you to solve the issue.
Thanks for contacting Fixya!
1helpful
Wireless network has disappeared.
After resetting it (pressing that inset button with a paperclip or pencil), try connecting to it with a wire (cat5 network patch cable). Login with the default of no username and "admin" password. If that doesn't work, it hasn't been reset yet (unless the manual tells you otherwise). Make sure the wireless is enabled AND that the SSID is set to broadcast, not remain hidden.
3answers
Internet lose on my wrt54g2
please reset the router
configure the router type ip address on the browser
may be 192.168.1.1
1helpful
Windows vista laptop lost connection to the internet
Start off simple. Try a different port on the router. If that doesn't work, try a new cable. If that doesn't work, go to the Device Manager in Windows. (Right-click My Computer, select Manage, go to Device Manager). Does the card look okay? Has it been disabled or need a driver update? If we're still looking at issues then I would take a look at your router security. How many DHCP licences do you allowed to be assigned? Also do you have security in place (WEP/WPA, Mac Filtering, SSID Broadcast)? If you are light on security and only have a few assignable DHCP licences, you may have neighbors leeching your internet access.
To clarify: DHCP assigns a network IP address to each device on its network. Most Linkys routers have a default of 10, you may have reduced this yourself. If you have, you've limited the # of devices allowed on the network. So if you have 3 DHCP licenses available, and a couple neighbors are leeching, your Dell may not get assigned an ip.
If you still need further help, let me know.
I would like to connect my wrt54g2 router to my dest top and my
try this...
Make sure you have wireless enabled on your router and on the laptop. For the router, on your desktop open a web browser.Type in 192.168.1.1 in the address bar. The default user name is blankand the password is admin. This will log you into your router. Oncelogged on, click on the wireless tab. Make sure that wireless isenabled and you have an SSID (also known as a Network ID). Also, makesure SSID broadcast is enabled. When this info is verified and set upyou can close the web browser.
Now move to the laptop. Click once on the network icon on the taskbar (the 2 computer monitors by the clock). Select "Connect or disconnect..." When the window comes up, select your wireless connection.
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
