My personal suggestion would be to go for these repair catalogs. I know this website www.reliable-store.com that i used to get manuals from, and they have all models online.
I also brought for my 1989 BMW, such old model, they had it and it was very good manual.
Go ahead, I bet.
Your windows are controlled through a body module called a "BCM", it can be tested by the dealer to see what the problem is, at this point that is what you need to do.
my apologies for delay in getting back to you.only just sorted this.turned out was the little control unit for sun roof causing problem.it is cable tied to the sun roof frame beside the sun roof motor and can only get at it by dropping the head cloth on one side.learned from a hyundi dealer the switches give a lot of bother,now and again the control units do too.many thanks.
check the parcel shelf has been refitted correctly as there is a micro switch on the left hand side that stops the second stage of the roof from opening
The air coming in due to the elastic band which seal ,which prevent the air noise to come in.It is leaking somewhere,now what you have to do is to test where it is leaking,close the sun roof ,pour water on the sun roof see where it is leaking,The elastic is not fix well,see for it or u must see if the elastic have not been broken some where ...hope that help you and fix the problem
refer to the owners manual, for instructions to put down roof by hand, they are not easy to follow, however, the manual key they refer to is in the fuse panel, the 1st lock to undo is in the middle section of the back seat, next the lock for the front section push down roof and lock in place. the warning light at this point will still be flashing, and the display saying roof unsecure. the bit everyone seems to forget is to go back to the middle back seat lock and relock, once that is done, display clears, and both roof and boot should work. i have no idea why this fault occured just hoping its doesn't too often. suggest also you always have engine on when operating roof. hope you find this usefull.
This happenrd to me the first few times after filling the tank. When the roof stops push the switch to up then back until movement stops then go back to down, eventually it will get rid of all the air in the system and the roof should start to work.
Hi, sit in middle seat facing forward. If seatbelt is mounted in roof over your right shoulder, the clip on the end of the seatbelt clips in down by your right hip. Then the 'free' clip clips in by your left hip in to one of the two seatbelt clips. If you have done it right you should have a lap/sash configuration with the belt form the roof running over your right shoulder. The roof belt is also 'inertia reel' and behaves the same as all the other belts. To get out of the seat belt undo the 'free' or middle point clip only. When you have finished altogether, press key in to end clip lock and store back in the roof. If you have problems getting clips in to holders press the release tab on the holder. Hope that helps.
