Put the bike on center stand.
Remove the outer drive belt casing, you will need to remove the normal stand to get at the bolts. A light tap to the side and it will come off.
If the drive belt is snapped, pull it out and make sure nothing is inside.
Loosen the rear pulley, and move it towards the front gear. Slip over the new drive belt and tighten the rear pulley back up. You should aim for around 2-3mm of deflection in the belt. refit the casing and the stand. Start her up and off you go :)
Vote for me please if this helps you, thanks.
