It is not $250, the price is correct, it is from a site called rockauto.com
On an '05 Corolla BCAS1298 is right on the money on replacing it. However unless you can find a low mileage used one the part is almost $1000 brand new from the Toyota dealer
Fuel pump sits under the back seat, remove back seat, there will be a panel, remove screw's, remove fuel line's, and harness to fuel pump (connector) and ring that hold's fuel pump in gas tank, lift fuel pump assembly and replace fuel pump, if your getting it done at a repair shop labor for this job to remove and replace is .8 tenths of an hour X there labor rate = your cost for labor.Call around some repair shop's will install your fuel pump if you buy the part.
what is a fortune?
The guy at the garage told me he hooked it up to the computer and said I need a fuel pump.
no computer tells u a fuel pump is bad, I would have had him do the job, if he is wrong then he would have to make it right, if he is wrong and u do the work and replace the pump then u are out about $125.00 DENSO Part # 9510001 Fuel Pump OE Manufacturer
Thank you so much. I think I will have him order the part you suggested, DENSO part 9510001 and let him do it.
Thanks again
Yeah, but he was such a good dancer
