To fix the high idle, replace the top oxygen sensor. I would drop the transmission pan and change the transmission filter. You can then check the old fluid for contamination and metal filings. Metal filings will clog the transmission filter and lead to low pressure that would cause delayed shifts
transmission worked fine just before we R&R the motor, does this model of vehicles transmission shift with the assistance of vacuum? we have a cracked vacuum line and when we pulled it off while the vehicle was idling, the RPM's went up. could this be a problem with the idle and shifting? would the idle sensor cause it to not start without the shot of ether as well?
Spraying ether is not advisable.Its a explosive and can fire up the fuel pump and engine.
Is
there white or gray smoke from the exhaust when you crank it? It may be that
some sensor is out of whack, causing the electronics to ****** or advance the
timing out of range for starting. With the ether giving it a helping hand, it
starts and the normal timing kicks in and allows it to run.
If no white some is seen from exhaust tail pipe then bleed the injectors and then recheck.
old gasoline can be the other possibility for this problem .You can try draining the tank and refilling with fresh fuel. Also get clean the fuel injectors / the throttle body.
Thanks. keep updated for any more query.you can rate this solution
and show your appreciation.
2002 pontiac grand prix-supercharged
just R&R a motor into car, car starts only with a shot of ether, idles high and wont shift right during a test drive. replaced oxygen sensor but still idles high and still wont start without a small shot of ether, any suggestions?
