you can use a external hard disc connector ,,, but still you must open the box ,, i think the guarantee is already void ,,, cause misuse is not guaranteed any way you must ask about the guarantee thing ,,,
i am telling you (HOW TO PROTECT MOBLE FROM WATER DAMAGE) now a days the water damge is common byut hoe to manage this is the main problem
SO,
when you suffering from water damge just calm down and one thing that after water damge dont rty to switch on the mobile just open the back panel and remove battery ,sim card and sd card NOW take a air tight container take some rice and put it into the container and and mobile also and close it tightly levave it for 45 min and afetr some u will see that most the water get absorb by the rice noe just take it to the shop and afetr this your mobile will be save and able to acces by you THANKYOU
As you say has become red and no power to the hard disk. First check the power cable for any loose connections and check if it give power to the cpu and the fan placed on processor starts working as you start the power. If fan it starts and with in few seconds stops then your power supply/SMPS is weak or damage. So replace it for proper working of your computer. And if after power on all fines but red led on monitor and no power to hard disk Try to replace the hard disk power cables because they are not working because of it no operating system is detected and led of monitor is red. After replacing hard disk cables hard disk starts working and still no display or red led on monitor check the vga cable for loose connection or replace it.If you are using vga display from graphic card try to get display first from onboard vga slot.After it your problem will disappear and your pc run smooth and fine.
hello,
plz tell us that you brought external or internal hard disk. if he brought internal hard disk then plz tell us that is sata or pata. if you don't know more abt hard disk then you see the label of the hard disk and if it is has 40 pins back side then firstly swithch off the power then you open your cabinet and put the power cable of smps and plug it to hard disk and then attached the 40 pin data cable to the motherboard and another point to the hard disk then turn on the power. then you see the new harddisk in window explorer partation it and use it.
thanks
ramesh
when you burn disks you have to choose the option "appendable disk"(or in simple words to create a disk where you can add information -data-later if you wish to do so)
If you just record the data on a cd without this option you will get the error -disk is full-
consult the authorized service cenetr of amxtor as they can recover data from damged hard disk . carefull while connecting to pc . as it can damage pc if circuits are broken
