1992 Ford F150 SuperCab Logo
Anonymous Posted on Jun 13, 2010
-turns over but won't start -changed fuel filter
-turns over but won't start -changed fuel filter and fuel pressure regulator -chaged spark plugs -there is some spark but it's not constant, Is this normal? -any ideas?
  • Anonymous Jun 13, 2010
    Battery and coil are good. fuel pump is working. inertia switch is good.
    where would i find the crankshaft sensor? motor is an 1988 351
fordexpert
Level 3:
  • Ford Master 5,692 Answers
  • Posted on Jun 13, 2010
fordexpert
Ford Master
Level 3:
Answers
5692
Questions
Helped
1976055
Points
17063
Check your battery as it supplies juice for the coil. Then check your coil or coilpak and the crankshaft sensor. The bad spark may be an underlying reason for how the truck has been running.
Do you know if the fuelpump is working? The Inertia sensor may have tripped while you changed regulators. You may need to reset the button on it to connect the fuelpump.
  • fordexpert Jun 14, 2010
    Check down where the timing pointer used to be for the crankshaft sensor. Since this is an older engine than a 1992 you may still have the grey module that plugs into the distributor. This module was the type that used a conductive cream to use when you mount the module to the distributor.
    If you have that type of module you also had a plug connector above the water pump going to the distributor. That type of system set base idle with the connector unplugged and still had a timing mark. The crankshaft sensor may be on the drivers side of the crank since the timing plate is still used on the passengers side of the crank.
    Modules were notorious for going out without warning. There is a special tool shaped like a short screwdriver for removing the mounting bolts without taking out the distributor. You can just pull the distributor if you want. Since you know the electric spark is inconsistent the module would be a good part to replace.
Have changed to crankshaft sensor the oxygen sensor spark plugs and wire and wont start even when it is turning over
Borrow a fuel pressure tester from Auto Zone and test the fuel system. It could be that you have a bad fuel pump or fuel pressure regulator. It also could be a plugged fuel filter.
1helpful
Won't start replaced feulpump and feulpressure regulator and still won't what could it be
Did you check fuel pressure at the injectors before and after you replaced the pump ?
And did you also replace the fuel filter ?
Is it getting spark to the plugs ?
1helpful
Won't start,has spark, has fuel
Are you sure the injectors are spraying if the pressure is zero ?
Have you checked the fuel pressure regulator ?
Are the spark plugs dry ?
1992 mercury sable will turn over but wont start
Make sure battery has a full charge. If it cranks good but won't start, check the basics. Have a helper crank it while you visually check for spark at the spark plugs, if spark everywhere, use a gage and check proper fuel pressure. I looked at info for the 3.8L engine, 35--40 psi. Also, after you build fuel pressure, turn off the key, see if fuel pressure holds for a bit? If the pressure drops like a rock, check for fuel pressure leak. Check the vac line for fuel pressure regulator, if it has gas in it, the regulator is faulty, or a leaking fuel injector. The pressure could also drain back through fuel pump.
Also, check fuel injector pulse, engine cranking. Any applicable trouble codes?
Smell of the crankcase oil dipstick, if it smells like gas, either you don't change oil and filter very often or the engine is running very rich for some reason.
1helpful
Problems
This symptom can be the fuel pressure regulator...as the least costly...it can also be an indication of a worn or defective timing belt...inspect the fuel pressure regulator first. Hope this helps.
1helpful
3answers
2001 Hyundai XG300L HARD TO START DONT START RIGHTWAY TAKE LIKE 5 SECONDS CRANK TO START,,,, SOMEBODY CAN GIVE ME ANY IDEA WHAT IS THE PROBLEM PLEASE THANKS !!!
hi martin i am shannon . you will first need to determan if the problem is fuel or spark related . for fuel just add 1 oz of gas into the intake through the throttle. you will need to remove the big black hose at the throttle . just pour the fuel in. if it starts right up then you have a fuel issue most likely a bad fuel pressure regulator. too test the spark i would get a spark tester . connect it to one of the plug or coil wires. set it to 25.0000 volts then have some one turn the engine over while you which for spark. if you get no spark you may have a bad crank angle sensor. hear is a spark tester i use . this one is at Autozone.
1helpful
It starts great but after we go somewhere and turn the engine off, it won't start until 45 min to 1 hr. It sounds flooded. but then after the time passes, it starts great again. have change mass flow...
Have a fuel pressure test done to find out if the pump or the fuel pressure regulator is at fault. If the pressure is low, the fuel pump is weak and can't keep up with the demand for fuel.
If it is high, the pressure regulator is at fault causing to much pressure rusulting in a flooding situation.
My 2003 malibu with turn over but not start fule pump is getting 55 lbs of pressure at filter and rail if you spray start fluid in it it will start and run until it runs out of start fluid could this be a...
Signs of a Bad Fuel Pressure Regulator
the vehicle will not start, if a bad regulator. Usually, this is a problem that is encountered in the morning when you start your vehicle. Many a times, the engine starts, but stalls shortly after starting. check the fuse and relay for pump. also remove line to fuel pressure regulator and if fuel in line, replace fuel pressure regulator. check for spark and also the timing belt. its one sign of not starting. if car runs fine on spray, I would not say its the timing belt or chain.
Fuel pump runs but wont start, their is spark,opened line at fuel filter only a dribble comes out 2.2 sunfire, turns over good
change the fuel filter or check the pressure regulator b trying to start car then pull the rubber fuel line from regulator if anything drips out in the least change it...cheap and easy
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
