I'm getting a 1320 code on my 97 pathfinder, reserach problem and looks like i have to replace the ignition coils, where are the ignition coils located?
0300 the dreaded multiple misfire code
0325 knock sensor
1320 ignition signal
Have you replaced the knock sensor(s)? Tested ignition module? Note: even if module tests good, it may still be the problem. Tests are not conclusive. Bad ground somewhere?
The ignition coil is causing the misfire. That is causing rich mixture which could case the oxygen sensor issue. You need to work from the ignition issue to the sensor. The reason is if you replace the cat and the engine is running rich it will heat the cat up to the point that the car might catch fire. Oxygen sensors are also prone to fail after about 60 thousand miles.
(171,172) replace MAF , replace air filter with o.e. type (1130) Check vac. lines and connectors to vac. solenoids
(1320) ignition coil primary failure, if all connections are good, replace all the coils
DTC Confirmation Test
Malfunction is detected when ECM does not receive signal from ignition
primary circuit during engine cranking or running. Possible causes are:
Ignition primary circuit open or shorted.
Defective power transistor (integral with ignition coil).
- Ignition primary circuit is open or shorted - Ignition primary circuit poor electrical connection - Faulty power transistor unit built into ignition coil - Faulty ignition system condenser - Crankshaft position sensor circuit
The most common cause of the problem is the ignition coils
