Make sure the oil level is correct. If the engine bearings are getting worn, the oil pump is worn or it's screen plugged, that can cause low-RPM weak oil pressure. Try running with 'high mileage' oil at your next oil change and always replace the filter. At some point, you may need to consider overhauling or replacing the engine. Good luck!
