Samsung SGH-Z300 Cellular Phone Logo
Posted on Jun 06, 2010
How to install theme this phone - Samsung SGH-Z300 Cellular Phone
Anonymous
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Jun 06, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
220
Points
11
Pls download themes from internet or GPRS
1helpful
How to install E63 themes?
There are three ways that you can install your Nokia themes on your phone. One is through over the air downloads, in which case, you just go directly to the site with your chosen theme, click on the link, and follow the instructions on your phone.
If you're downloading the themes on your PC, there are two ways you can install it on your mobile phone. One is through the Nokia PC suite, and the other is through Bluetooth or data cable transfer. follow these instructions
Using Nokia PC Suite:
1. Connect your phone to your PC and turn on the Nokia PC Suite or wait for the application to start.
2. Click on the "Install Applications"
3. When a window appears, browse to where you have saved the downloaded themes using the left part of the window.
4. Select your chosen theme and then press the arrow in the middle of the window
5. Follow the instructions on your phone screen and you're done.
Bluetooth or Data transfer (only for N-series and newer phone versions)
1. Data transfer. Connect your phone via USB cable and select "data transfer" on the mode menu. When you connect your phone and it shows up as a removable disk, transfer the theme on your phone's storage card. You can install the theme by using the file manager and selecting the theme to install. 2. Bluetooth. If your friend has a theme on their phone, you can have them transfer it on your phone via Bluetooth transfer. The theme will appear on your messages and to install it, simply click on the transferred file on your messages and follow the prompts.
hope this helps...
1helpful
How can i put a theme my lg km555e
Try this steps :
- Download the themes file, like from here :
http://www.umnet.com/mobile-themes/0-2974-0-LG_themes_240x400-0
- Connect phone to PC
- If your PC Suite have direct application installer, you can double click the themes file to direct installation
- If your PC suite don't support it, you can do it manually. Copy the theme files to certain folder in your phone memory.
- Disconnect phone from PC
- Open File Manager in folder where you saved the themes file.
- Click the file > option > install.
- Done, check your Themes folder, click your new theme to apply
If this helpful, RATE please !
1helpful
2answers
Theme installation is successful but my theme didnt change
Hey welcome to fixya. I hope u 'll be fine if u have installed your theme then it 'll not be change on your phone till u 'll not apply it.
  • After installation find themes icon in your e65 it exist by default somewhere in cell phone open it and go there and see there is a theme which u have installed open it and apply it on your phone. It will take 2 seconds and new theme will change on your phone.
problem 'll be solved If u like this solution or way to solve the problem den please do rate me. THANKS
1helpful
2answers
I cant install my theme
hi... is your theme is a built in theme? if it is not try to look for the extension name of the themes... maybe you used a theme that is not supported by your phone... and if it is built-in theme try to ask the product distributor or the store where you bought your phone...thank you very much..
How to install theme in sony ericsson w302
plug you phone into your pc.. if it comes up with removable disk then open the folder and select themes and put your theme file into that folder and install it onto your phone by locating the themes folder
How to install a themes for my motorola L7
Your phone supports only jar and jad files. so you can find themes at mobango.
Just download and tranfer them to your cell, install them and enjoy
How to install themes to my motorola v3i?
go to this sites, this is the link of theme installer
http://www.66mobile.com/how-to-install-themes-skins-on-motorola-phones.html
1helpful
To install themes on your l7 you will first have to download skinman and p2k drivers try the latest one (you can search for these softwares in google) In your phone change the default USB settings as data & fax connection then connect your phone to a usb port to which you had never conected your phone before then you will get a message that a new hardware is found select to "install now" then select "Install from a specific location" tick the "include this location in search" click "briowse" and select the p2k drivers folder that you had downloaded. For example "D:\Motorola System\p2kdrivers_2.9" Then click "next". It will install your phone. Then again you will get the same kind of message do the same for all until it says your phone has been installed and is ready for use. Now you have done half of the job. Now run Skinman the file list will be loaded. select install.You will get a message just select ok then browse and find the theme that you want to install then select open the theme will start installing. once you have added the desired number of themes select restart phone. now you are done.
How to install a themes for my motorola L9
hi ur phone will not support all kind of themes.. there are seperate themes available for motorola phone alone.. u can download those themes in www.zedge.com... after downloading u can transfer these thems into ur mobile and u can apply to ur mobile..
thank u rate me
42helpful
9answers
first you download motorola skin loader and then you download motorola themes .ski file format, now you connect the mobile into computer and run the motorola skin loder the add the .ski file and install into your motorola l7 mobile phone.
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
