Microsoft Xbox 360 Console Logo
Posted on Jun 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Play on laptop with hdmi cable
I,m trying to play my xbox 360 on laptop with hdmi cable, is this even possible?
Anonymous
Level 3:
Guru:
  • Master 374 Answers
  • Posted on Jun 05, 2010
Anonymous
Master
Level 3:
Guru:
Answers
374
Questions
0
Helped
64777
Points
1078
I believe you can do it with a little work. First you will have to have a available HDMI Input to your laptop. After this you will need neccessary software to get it running.
Have you though about buying a TV Tuner with the software you need inside it???
Thats the route I would look into.
If you already have this or can't get this to work send me a comment with your questions and I will get back to you the next time I am on
2answers
Playing bluray through xbox one on toshiba TV
Make sure the display resolution is set correct for your TV,
How to change the display resolution for your TV on your Xbox One...
Also make sure the TV is on and set to the correct HDMI input before using the Blu Ray.
It is also possible the TV does not support HDCP, if not, it will not work with the XBOX one Blu Ray. You may be able to use the Component (Red Green and Blue) cable though.
I have an xbox 360, but i have a ps3 connect to the tv via hdmi. i swapped the hdmi cable to the xbox and powered on. i had all the cables in the correct position, the correct av selected on the tv, but...
Have you tried disconnecting the HDMI cable from both the TV and the console and then trying to reconnect?
Y+RT does not reset controllers for the Xbox 360, so not sure what you are attempting there?
What type of TV do you have? It appears the issue is with either your cable or the TV seeing that you are having the same issue with both your PS3 and Xbox 360.
I still think your first step should be to disconnect all cables from both ends and reconnect. (with poer off of all sytems of course) If this doesn't solve your issue then submit further information on your setup such as TV make and model and I can research other possibilities.
Turned xbox on. tv said "not supported mode". turned off . completely unplugged, re plugged, switched hd/tv switch, no results. what is the problem?
try using a xbox 360 HDMI lead, you can buy one here:
http://www.play.com/Games/Xbox360/4-/12361467/Official-Xbox-360-HDMI-AV-Cable/Product.html?_%24ja=tsid:11518'cat:12361467'prd:12361467
3answers
I can't get my Xbox 360 to work over HDMI anymore, but other HDMI devices work and the Xbox 360 also works with other TVs over HDMI.
Reset your TV, try unplugging it for a while, if that doesn't help, try restoring or resetting it to defaults, there should be a function for that somewhere in the menus of the TV. that should solve the issue, if it still remains, check the cables and if possible try another hdmi port.
2answers
Black pixels on my Tv when I play Xbox 360.
It may be your cables, if you are using HDMI cables a low signal from the cables causes screen "garbage". Try using a different set of cables. I got my HDMI cable off amazon.com for 5$ so they're not that expensive just read the customer reviews before ordering them.
2answers
No audio
if possible use the hdmi as a video feed and non-hdmi as a audio feed i am not sure if hdmi even carrys sound.45687d7.jpg
3answers
Is it possible for xbox360 hdmi to connect to the hdmi of laptop?
If there is the same number of pins and you can find the drivers for it than it could be possible.
1helpful
Cannont connect Ear Force X3 with my HDMI set up .
Is the problem that you're using a single HDMI cable to connect your Xbox to your TV? If so, this Turtle Beach article should help... ________________________________________
HDMI and Connecting Ear Force Xbox Headphones
The current Microsoft Xbox 360 series of gaming consoles allow the use of HDMI cables for simpler hookup to home theater systems and Hi-Definition televisions (HDTV).
The Xbox 360 Elite (the black one) comes with two additional cables, an HDMI cable and a separate AUDIO cable that provides a pair of RCA jacks (red and white) and an optical digital audio output (S/PDIF Out). With this cable package, you can easily connect any of our X-series headsets and an HDMI-connected television at the same time.
This Xbox 360 HDMI Cable package is available as an extra-cost option from Microsoft: http://www.xbox.com/en-US/hardware/x/xbox360hdmiavcable/
Here's a more in-depth explanation of the Xbox 360 HDMI Cable and how it works: http://support.microsoft.com/kb/937899?sd=xbox
[NOTE 1:] The standard Xbox models do not come equipped with this cable set. The HD cable they have obscures the HDMI connector, so that the two sockets cannot be used at the same time. If you only have this stock HD connector (component video, composite video, stereo analog audio and optical digital audio connectors), then you will not be able to use the HDMI connector at the same time.
In order to use both sockets at the same time (HDMI and A/V) you'll need to purchase the Xbox 360 HDMI Cable package described above.
[NOTE 2:] The current Xbox 360 Elite Holiday Edition (Fall 2009) does not come with the HDMI Cable set.
___________________________________________________________________
Some companies make aftermarket HDMI cables for use with the Xbox 360, but these may not provide the dual RCA jacks that carry the 2- channel analog audio necessary for hookup of the anlog-only Ear Force X-series headsets. If this is what you have, you may need to find another way to connect your Ear Force X-series headset.
The TOSLINK digitally-connected X-series headsets can be always be connected using optical digital "Toslink" connections (and that's the best way to use them!).
The oldest white-and-gray Xbox 360 models DO NOT have an HDMI port. With this particular (obsolete) model, you cannot use HDMI connections, but you can use any of our X-series headsets.
Current Xbox 360 models all have separate HDMI and A/V ports ("sockets") on their back panels.
Here are some suggestions for alternative connection schemes:
XBOX 360 AUDIO PLAYS THROUGH TELEVISION SET:
For X4 and X41: Your best bet would be to connect the Xbox optical digital audio out to the X4 transmitter's optical digital input. Then connect the X4 optical digital output to the optical digital audio input on your HDTV or home theater amplifier.
[NOTE:] Some HDTV systems have an optical digital audio output that will not transmit Dolby Digital/DTS encoded digital audio, only stereo PCM audio will be passed. In this case, you must connect as above.
For X2, X3 and X31: You can use the Headphones jack or the Audio Out jacks on your TV to connect to the Audio In jack on the Transmitter.
For X1 and X11: You can use the Headphones jack or the Audio Out jacks on your TV (if available) to connect to the headset's analog Audio Input.
NOTE: Please make sure your TV has Audio Out jacks. Some TV's only have Audio In jacks.
Audio In jacks only accept incoming audio signal; they do not send audio signal out. If no audio signal is being sent to the headset, no sound will play from the headset.
You may need to purchase a suitable adapter cable in order to connect the TV audio output(s) to the Ear Force X-series headset's transmitter or Audio Input plug.
- Connect the HDMI cable so that the Xbox 360 plays its audio through the TV.
- For X1, adjust the Dashboard > Settings > System > Voice in the Xbox 360 so that the talkback and game sounds are played together (Play Through Speakers). - For X3, X31, X4 and X41, you should set this to Play Through Headset.
XBOX 360 AUDIO PLAYS THROUGH HOME THEATER RECEIVER (except X4 and X41): This is exactly the same as the above, except that you will use the receiver's Headphones output jack to connect to the Audio In on the Ear Force Xbox-compatible headset's Transmitter (X2, X3, X31) or the green Audio Input plug (X1).
- You may need to obtain a shielded audio cable with 1/4" stereo phone plug to 1/8" stereo mini-phone plug ends. The 1/4" phone plug goes to the receiver's Headphones jack, while the 1/8" mini-phone plug goes to the Audio In on the Ear Force Transmit- ter (X2, X3, X31) or Audio Input plug (X1).
- Adjust the Dashboard > Personal Settings in the Xbox 360 so that the talkback and game sounds are played together (Play Through Both). For X3 and X31, you may also set this to Play Through Headset.
Just bought xbox 360 to play on my hd ready 32"samsung tv,the console came up with message thatgames need to be played at 60 pal,so i changed it from 50 to 60 and now the picture(mostly the writing)is...
ive the oposit problem i want to play hitman which is 50hz game but im using a hdmi cable and it isnt possible to run it in 50hz , 60hz only i think so if you get the new hdmi cables it should fix your problem (if you have a hdmi port you should be using it anyway for the best picture)
Top Microsoft Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
ELECTRICKSUSA
ELECTRICKSUSA
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
