The pressure switch has to be checked.Either the switch is got loose or its worn out and the switch needs replacement.
If the switch is checked out OK then check the valve which gets command from the switch to open and close.If the valve is cracked or blocked it needs to be checked and replaced.
And for temp problem the heater connections needs to be checked.Also the heating coils and element needs to be cleaned and checked.
Thanks. keep updated for any more query.you can rate this solution
and show your appreciation.
