What is the choke position on 2004 klx 125
SOURCE: type of oil for a klx 125 dirtbike
The gearbox gets 10w40 motor oil.
Please rate this answer. Thanks afiala93!
SOURCE: 2004 Klx 125 only runs with choke on. Barely starts
Mixture is off on the Carb, try backing the mixture screw out a quarter turn. Better/ Worse?
SOURCE: my KLX 125 2004 will turn over but wont idle
Might check: Air filter, choke malfuntion or sticking, dirty carb (idle circuit), valve adjustment, and sometimes a weak spark (cap, plug, wire). Could need a new top end (check compression after adjusting valves) or a vacuum leak in the intake manifold (cracks, petcock line off...not sure if this model uses a petcock vacuum shut off). Good luck.
SOURCE: 2004 klx 125l bike ideling
How long has the bike been sitting? The gas may be bad or the carb might need to be cleaned out or choke may be sticking.
SOURCE: can you adjust the seat height on my kawasaki 125?
No what you can do is take it to some one who does custom seats and discuss having it re done with thicker foam piece raising it to your comfort.
