SOURCE: does anyone know of any tranny probs. w/ 04' YZF-R6?
i have a 2000 yzf r6 and second is going out of it $1500 to fix the guy said i was lucky it lasted this long (27,000 miles) so they must be known to do this
SOURCE: Lost my key.
i dont think so, you could contact yamaha dealer and ask if they can order you a new key from the chassis number, or remove the ignition or seat lock if you can and take it to a good locksmith to make you a key from the lock
SOURCE: Find a rebuild kit for 2000 Yamaha YZF R6
your best bet it to order back threw the dealer, but they should offer some kits for the bike threw after-market company's like partsunlimited, lp "lockhart Phillips", and maybe tucker rocky street, at a better price but you may have to buy some parts extra it may not come in a complete kit like the factory offers.
SOURCE: need to take lock cylinder out
You will need the lock in the off position but not in the park position. With bike in park it will not allow you to move steering head from side to side. Disconnect battery. From underneath you will have to remove the bolts holding the lock in place. You will need a 3/8ths drive and extensions. I believe it's a 10mm socket but I may be off by a millimeter or 2. Remove bolt(s) on one side then turn steering head to other side and remove bolts there. Pull down lock out of steering head and disconnect connector. Installation is reverse of removal.
SOURCE: What is 2001 yamaha yzf 426 paint code
Frame color:
Deep Purplish Blue Metallic C (DPBMC)
This is Yamaha's color designation which is a dead end since they don't sell paint. Try Colorrite.com as they specialize in motorcycle oem match paint. This color is a 2-step process and requires the correct color primer to come out right. Color rite can fix you up with the proper coatings.
