may need a backflow preventer in the waste line under the sink..it is basically a ball on a spring..designed to make the water go only one way..I am guessing the wasteline was opened up with a plumbing snake..that pump may have too much backpressure from the head line..
This could be a problem with the capacitor that has gone bad or something stuck on the blade or impeller and is not allowing the waste to be pumped out. Typically when the capacitor has seized up or there is a clog on the drain pipe, blade or impeller; the unit will just hum and not pump the waste out and eventually back up on the toilet and overflow.
You cannot use a cheater, studdor or mechanical vent or an AAV on any Saniflo product. As they are considered one way vents, they only allow air to flow one way. Saniflo pumps must have an 1 1/2" vent pipe vented to the open air, air must flow in and out of the vent pipe at all times, otherwise the pump will short cycle and the solids will not leave the toilet. You will have to flush it several times to get rid of the waste and eventually the motor will go bad. Make sure is vented properly.
Typical saniflo costs about 500 quid incl vat from plumbase, prices vary according to what you need it to do.
It keeps making noise becasue the pump is still trying to get rid of the water inside.
it can't get rid of the water most likely because their is a blockage in the waste water pipe.
if possible follow where the waste pipe runs to. if it goes in to a loft or somewhere else VERY COLD there is a good chance that it has frozen somewhere along the pipe.
If you are tying to pump the toilet waste vertically (upwards) then as soon as you turn the power off to the saniflo, the waste will fall back down and in to the toilet - or over the top in your case, sorry!
You might want to accept the inevitable and get a bucket and start removing the waste water from the bowl. Make sure that you have rubber gloves and I suggest goggles and something protecting your mouth - in case you get splashed.
Easiest solution, is to remove the excess waste water, turn off the saniflo, pour some bleach in to the toilet bowl, then cover the bown securley with cling film to keep the rank smell at bay.
Other wise, start tring to follopw the waste water pipe and warm it up, either by directly or indirectly (warm air gun) or by warming the area around it.
Personall;y i am using the easy option. the cold werather won't last forever, but can you use a toilet elsewhere in the meantime.
In the meantime, Saniflo claim about 15 years as the lifespan, but i have never know a saniflo to make it past 3! they are not ideal, but may be your only option.
consider whether you could get a proper toilet waste pipe put in, as it WILL save money in the long run...
Probably the waste pipe blocked, it should have a rubber join that has worm screw clips securing it, I connect a hose to the"up" pipe and flush the blockage out.
We have a maserator in en-suite which serves the toilet & shower, We moved in to house 6 years ago and it was already here. After having guests stay a couple of months ago the maserator hasnt worked properly. When we flush the toilet, the water rises and whilst the cistern is filling with water, there is a humming noise for a couple of minutes, then the water rushes back down and there is a clonk and the water bubbles back up through the shower plug hole.Any suggestions as to what this problem is & how to fix it please?
These usually have a larger drain line than a shower or bath. If you are draining into a smaller drain then there will be a considerable amount of backing up. This is not a good idea. hope this helps. Good luck.
