Usually when the vacuum fails to start, a short has occurred at the Switch or Motor. Motors have brushes that in some cases wear down and fail after a long time in use. In some cases, dirt gets into a motor and acts as a resistor whereby electrical contacts fail to communicate with essential parts. A belt may seize up around the motor shaft or brush and bun out the motor.
Look inside for one of many thermal cutouts (button type) test each for continuity (with the unit unplugged of course). Also look for burned wires and repair or replace them. If you get it running and it works fine... we're done. If it still acts up then replace the magnetron and or the capacitor.
Sorry to tell you the bad news but I have to. Please do not loose time to try turn the engine.You cause more problems inside the engine. Since you cracked the oil pan and you drove the car since it died,you seized the engine, you manage to turn the rod bearing on the crank shaft and the rod as well because there was no oil to avoid friction. What you should do? Ask an expert to check your car and give you the correct advice. Do not try any more to start the car.
Add a comment for more free help. Also take advantage of fixya expert assistance live. For a price, expert works with you while you work on timer or any do-it-yourself project. Fixya is always less expensive than a service call.
1. Turn off both your computer and the monitor.
2. Unplug the video cable from the back of the computer.
3. Turn on the monitor.
If the monitor is functioning properly, you will see a box in the illustration below.
This box appears during normal operation if the video cable becomes disconnected or
damaged.
4. Turn off your monitor and reconnect the video cable; then turn on both your computer and the
monitor.
If your monitor screen remains blank after using the previous procedure, check your video
controller and computer system; your monitor is functioning properly.
Warning
The Power supply inside the monitor can be hazardous and donot open the monitor while power on.
Donot work with the monitor when it is open and the power supply is on.
If there is something wrong with the input signal, a message appears on the screen or the
screen goes blank although the power indicator LED is still on. The message may indicate
that the monitor is out of scan range or that you need to check the signal cable.
yes it may very well be the horizontal output transistor or the voltage regulator ic or a shorted rectifier diode on the power supply or the b+ capacitor on the powersupply good luck
Either your fuser lamp is not coming on or the thermoswitch ( acts as a fuse)or thermistor ( acts as a temperature control )has a problem.
If you do not know waht these are then you will have to contact a service tech.
