These machines won't spin untill the're empty, so your problem would probably be the drain function. It's not uncommon for the pumps in these machines to get something jammed in them or even for the pump itself to fail. The pump is accessed from underneath the cabinet...Most important to empty the machine before removing the pump!!!..Probably best to call a tech, because the pump resistance should be checked.. A failing pump can cause other components to fail as well......Not a big job for a tech. Good luck...Nomess
