I have a Panasonic Split air-con unit model CS-A24BKP and the bottom directional louvre won't lift up remotely or otherwise. It can be moved manualy but won't stay up. Any ideas ?
Thanks. Lou.
SOURCE: electra remote wont work with electra air con.
hi.you should have a sticker under the indoor unit head unit or on the side.
SOURCE: need filters for air conditioner
https://spares.bigwarehouse.com.au/index.php?cPath=137_176_4994
Use this to buy your product online :) rate this!!
Testimonial: "thankyou so much your help is greatly appreciated fantastic "
SOURCE: My panasonic cs-2470kr split air con is leaking
Find the drain on the outside of the house (should be located near the condesing unit outside) it is pvc and as I said it should be near the outside unit. This pvc will be sticking out of the house to which you can take a wet/dry vac and hold it to the end of this pvc pipe and it should remove the algae that is clogging up your drain pan. This is the easiest way to unclog an a/c unit. Going to the inside of the furnance can be done using a wet/dry vac to remove the debris in the drain pan however, the clog could possibly be in the a/c condensate drain trap that is why I suggest going to the drain on the outside of the house and removing the clogg that direction.
Good luck on repairs.
Dave
SOURCE: Not Cool
Measure room and calculate btu's
Formula Length times Width times Height Times Eighteen divde by Five.
Example: 12 x 15 x 9 x 18 / 5 = 5832 BTU's
