Hi! this is a common trouble,this kind of a phone. Just reset it to factory default setting,so it will works normal again. Hope it may helps, feel free to ask whatever the result.
Sometimes a phone won't turn on until you have enough charge in the battery to enable this. What I mean is if the battery is so flat, it might take ten or so minutes to start to so a charging state.
is the message from ur network service provider or else from lg people
if its from lg then it should be of something important
why dont u put the message here so that more clear answer can be provided
My LG Vu got wet and now it displays the message "emergency download". I'm in the process of letting it dry. What else can I try to get my phone working again? Thanks!
Take out the battery....then put it back in. Do not try to turn on the phone yet. Next plug the phone up to charge. Wait until the charging screen appears and then power the phone. Worked for me.....good luck.
pop out the battery. Connect charger to phone. press the power button. screen will read " insert battery". Insert battery. After the screen reads "charging" , press power button. If you turn the phone off, you will have to repeat these same steps.
Problem fixed! Press and hold 5 key and power on key together. Remove the battery, then replace and try again. I had to do this a couple of times before it worked, but now everything seems ok.
