Menu > Settings > More > Security > Enter Lock Code > Delete/Reset > Reset Phone Where the default lock code is the last four Numbers associated with the phone.
Does your LG KE850 Prada work only with your current service provider or, when you insert a SIM card from another network, do you see any of the following messages?
Enter Subsidy Code
Enter Subsidy Password
Enter SIM Unlock Code (Simlock)
Contact Service Provider
Insert Correct SIM Card
Wrong SIM Card
Incorrect SIM Card
Phone Restricted
Can't Undo Restriction
Locked Return For Service
Enter Unlock Code
Enter Special Code
If so, your LG KE850 Prada is LOCKED and we can help you remove this lock on your LG KE850 Prada in a few simple steps, allowing you to use your phone on any GSM wireless network anywhere in the world.
You will not have to mail in your LG KE850 Prada. No Hardware or Software required. No technical knowledge required at all. Simply provide us your LG KE850 Prada’s IMEI number and we do all the rest. Three Simple Steps
Simply provide us your LG KE850 Prada’s IMEI (which can be found by typing *#06# into your phone), during check out.
After order placement, the Unlock CODES together with easy to follow instructions guides will be sent to your email address within the time frame given.
If you have forgot the codes for your mobile you can unlock it by using the last four digits of your phone number or four zeros. If these codes are not working you can contact your network service provider to get the unlock codes.
If you need to reset your mobile then press the "Menu" button,from main menu scroll to "Settings/Tools" and select the option by pressing the center "Menu/OK" button.Scroll to "Settings" and select.Scroll and select "More". Scroll to "Security" and press your "Menu/OK" button.Enter in your phone's security code when prompted.
Select "Reset/Erase", then "Reset". A warning message will appear.
Press the "Menu/OK" button, then highlight and select "Yes" to confirm the reset.
This is a small tutorial on how to hard reset the lg prada on request for forgotten security code.
Turn the prada on without a simcard and wait for the insert sim screen.
On the touch screen hit call, after enter this code 2945#*#. and you will see a menu pop up headed "Engineering menu".
scroll down to factory reset hit that and wait for it to reboot.
