Do you see blinking light on your CD Drive. If not, you may need to check you power supply to CD Drive.
If yes, may be door looks jam, opening up once may remove any dust to smooth it out again. To open up there is small pin hole on cd drive, generally on the right side, use needle and press it through the pin hole, it will eject the CD Door and you can pull it out completely.
SOURCE: cd/rom drive door will not
take a long pin or straigten paper clip and find a hole infront on the drive insert it and gently push it till open.
Take care sometimes u see cd disc spin while it come out dont touch it until it stop
