Bosch job radio was working fine Turned it off for lunch and it never turned back on. Battery charger works.gfi plugs work but nothing on frount works. No power
It tends to the problem of power supply .Check the connections are proper . If the connection is fine then you need to take to repair shop to get it repaired . Power supply unit is failing due to bad blown fuse or bad capacitor inside the unit .
Hope this helps .
Http://www.ereplacementparts.com/bosch-pb10cd-2610920592-advanced-jobsite-radio-parts-c-128_18802_8884.html
I would say it is most likely a power supply problem, you need to look there first to see if all the Voltages are correct. These websites above and below, may offer some assistance, I have searched, the net, but there is NOT a lot of mention. I would advise contacting Bosch, and ask for a service manual, that way you at least have a chance of a fix.
http://www.ereplacementparts.com/bosch-jobsite-radio-parts-c-128_18802.html
So, it is nearly always my professional opinion that one should always get a "Quote" form the manufacturers recommended service center, Bosch in your case, you should contact a local or head office, and ask for a referral to an authorised service center. Now, I cannot stress how important that last point is. It is even worth the cost of shipping. you see an authorised service agent, will have trained staff, trained on their brand, also they have first hand access to parts, original parts. This will actually save you money and ensure you can actually get it back fixed. Of course asking for a "Quote" also gives on the option of repair or replace.
If it stopped working suddenly you may need a software reset.
Check page 12 of user manual.
http://dl.owneriq.net/6/6f1ba2d5-5cfe-4ab4-bbaa-e95651063273.pdf
Hope this helps. If not please post a comment with some more details, eg., voltage on battery, have you tried new battery?
runs off power cord never off battery. tried the reset thing and nothing.no power to radio or cd player
could it be power supply or just a power button to turn on and off ?
Seems to be the best answer to my problem
