Computers & Internet Logo
Posted on Mar 29, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
SimpleTech 250GB USB, 3.5" external hard drive. They say in manual "USING ARCSOFT® TOTALMEDIA BACKUP & RECORD. Go to the root directory on your SimpleDrive external disk drive, and then double-click Setup.exe to launch the TotalMedia Backup & Record installation wizard." I have no idea how to get there (root directory, I don't see any ArcSoft in my list of programmes). They main reason I got this drive is I need to unload all my stuff from pc in order to fix it ( to reinstall the windows from XP64 back to XP32 because they say it causes many troubles in my pc including that I can't enable DirectX's though I had this problem even long time before I installed XP64 and put a new DVD drive). Any advise on whole situation or particularly on hard drive would be very much appreciated. Thank you. Denis [email protected]
Anonymous
Level 2:
  • Expert 236 Answers
  • Posted on Mar 30, 2008
Anonymous
Expert
Level 2:
Answers
236
Questions
Helped
130010
Points
715
With the usb drive connected to the pc,
Open my computer, there will be a new drive listed there (ie: f: ) or something like that.. This is your usb driver.. double click on that, and in there, there should be a setup.exe file, double click that to install Arcsoft.
My computer will not recognize the drive. Does it have to be connect to a power supply? I have it connected to a usb port
Windows 7 does not recognize SimpleTech 250GB external USB drive ...
answers.microsoft.com/...does-not-recognize-simpletech-250gb/f7ceccd0...
Just bought a new computer, running Win 7. Drive worked fine on Win XP. ... Windows 7 does not recognize SimpleTech 250GB external USB drive ... I find it hard to believe that a external USB 2.0 drive can't work with Win 7. There must be ...
SimpleTech dvi hdmi pc Hard Drives Questions & Answers ...
www.fixya.com > Forum > Tags > dvi hdmi pc > Hard Drives
Question about SimpleDrive 160 GB External USB 2.0 Hard Drive ... Question about250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive ... my PC does not recognize the external drive 96300-40001-001 Driver Problem: Check whether ..
Where can I find a power cord for simpletech
Hi, I think I found one for you 5V AC DC power adapter for SIMPLETECH 96200 41001 075 250GB USB hard... . If it is correct, it is OK to just find ANY power cord with Output Voltage: 5 Volts DC and Amperage: 1 Amps. It just need to fit in.
For the last couple of months I've had to un-plug, then re-plug my EHD to get it to be recognized by my HP laptop. Today my HP says that the device is not regonized. Can the Signature Mini be re
If you have a SimpleTech SimpleDrive connected to your computer and you're experiencing problems with the external hard drive, there may be several reasons why it's malfunctioning. Troubleshooting your computer can help rule out common problems and the possibility that the hard drive may be defective. If you recently purchased the device and suspect there is something wrong with it, return the defective drive to SimpleTech or the reseller for a replacement. Incompatible USB Port Problems SimpleTech SimpleDrive plug and play options makes it easy for you to connect the device to your computer. But you may encounter problems if your computer's USB (Universal Serial Bus) ports are not compatible with the external hard drive. Make sure your ports are powerful enough to operate the drive. USB 2.0 ports are recommended, but if you're using an older computer with 1.0 ports, the hard drive will function much slower or you may receive an error message that the device is not compatible with your system. b> Missing External Drive Letter If you're unable to find the SimpleTech external hard drive's letter on your desktop after you have installed the drivers for the device, it's possible that the external drive may be assigned to another drive. Sometimes, the hard drive is assigned to a network drive and you may need to manually change the drive's letter in Disk Management. b> SimpleTech SimpleDrive Incorrectly Formatted b> SimpleTech SimpleDrive is normally pre-formatted for Windows NTFS (New Technology File System), but Mac users may need to copy the backup software and reformat the external hard drive for FAT32 or Mac OS to be able to use the external drive. If the external hard drive is not formatted correctly for your system, it may not function or work properly. b> External Hard Drive Inaccessible If you receive an error message that says "Drive Inaccessible," the SimpleTech SimpleDrive may not be able to read the service area of the platter. If the external hard drive emits a loud or abnormal sound, this could mean the device is failing.
Test the drive on another computer to see if it is working properly. Otherwise, the external hard drive's surface area may be damaged or corrupted.
Replacing a Defective Hard Drive You can return a defective hard drive that is under warranty to SimpleTech. The manufacturer will exchange the device if the seal is not broken. But if you break or tear the seal on the case, any warranty claims will not be accepted and the device will be returned back to you. SimpleTech will only accept the device if you contracted a commercial data recovery company to retrieve critical data from the external hard drive and the seal needed to be broken. Before returning the defective drive, you will need to secure a RMA (Return Merchandise Authorization) approval number from SimpleTech and furnish any invoices or documentation regarding the data recovery company's services
or if its a usb external drive you might need a usb 3 card installed on your computer your computer might not have enough usb output power USB 3 card will provide more power when needed to the device to gain maximum throughput and conserve power when the device is connected but is idling http://blog.premiumusb.com/2010/09/usb-2-0-vs-usb-3-0/ these can be purchased on Ebay cheap and easy to install http://www.ebay.com.au/itm/PCI-e-PCI-Express-USB3-0-Card-new-NEC-720200AF1-chipset-/330608109325?pt=LH_DefaultDomain_0&hash=item4cf9c7670d for roughly $9 or $10free postage Hope this helps.
1helpful
My simpletech 250 gb external hard-drive is not working. anyway to fix this manually?
change the usb cable firstthen >control pannel > administrator tools> disk mannagment if there is any physicall disk so ask again
Do i need an external power to use by usb simpletech 250gb drive, and do i need a software to use it?
no its plug and play............all is needed is usb connection windows xp and up will power the drive.........before you add any thing on to it go to my computer once plug in format the drive and give it a name (a letter will be given automatic)
I want to install arcsoft totalmedia back & record on my computer. The directions say to go to the root directory on your simmpledrive external disk drive and double click setup.exe to launch the...
The root drive is always the drive letter with nothing after it.
If your external drive is drive E, then the root is E:\.
You can see this in Windows explorer.
1. Right click on the My Computer icon on the desktop.
OR
Right click on the Computer name in the list of components to the right of the program list (Windows 7, Vista)
OR
Click Start, run, type the word explorer and click OK.
2. Look for the drive letter that says "simpledrive"
3. Click on the drive letter and look for setup.exe
I hope this helps.
2helpful
I backed up my entire computer on my SimpleTech Pinin Farina external hard drive and now I can't figure out how to find a file on it that I need. I see all the backup files, but I can't figure out how to...
Backup software compresses the files and encodes them to an image file made up of a series of sequenced files. The same software you used to do the backup should have the restore options needed to locate desired files. SimpleTech website shows Fabrik to be the name of the backup software.
If you utilized, there's also an online backup site used to store files. Following link is the users guide:
http://www.simpletech.com/support/guides/user-guides/60000-00168-001.pdf
Simpletech 500 gb external hard drive
There is a power consumption work-around untill a Y usb wire can be purchased; the main power cable must still be used at all times but this workaround should only remain temporary!!!
Simpletech should have included this so laptop users could use the drive as their capacity is better than the packaged slimmer simpletech portable backup drives for laptops, which does include the Y cable....
1) unplug usb while powered and unknown hardware is present on laptop...
2) turn power switch off from the external HDD...
3) return power switch to on from the external HDD...
4) plug in usb connection to laptop...
Autoplay should read from external HDD!!!
**** Save some $$$ and buy a Y shaped cable to provide sufficient amount of power from laptop usb
ports, cause it's necessary to use 2 of your ports to provide power in addition to the main power from HDD to wall****
ADONIS
2answers
SIMPLETECH 320GB
One thing to remember is the some of the Simple drives requires the USB mini to conect to the drive and the TWO USB connects to be plugin to the computer.
Grand Canyon Tech
Grand Canyon Tech
