Did the conversion kit give you an LP orifice for every new gas valve? LP gas orifices have smaller holes than Nat gas orifices. Can you smell gas when you turn on the IR burner by itself? Some burners styles have an air adjustment on the end that fits over the orifice. Make sure it's getting enough air. Also make sure your ignitor sparker is positioned where the spark can ark against the top of the burner. Ducane grills have rotary ignitors, so turn it (with gas off) and see if you can actually see where it's sparking. If it's not sparking in the right place, it will be difficult to light.
Testimonial: "As I expected - conversion kit did not include a new orofice for the IR burner. Conversation with Ducane indicated no conversion is available - interesting in that I purchased the kit from Ducane two years ago. Thanks for your help"
If you know the BTU rating of the IR burner, the orifice can be manually converted. I've done it many times. Nat gas orifices can be drilled and fitted with a spud, which can then be redrilled with the appropriate smaller LP gas hole size. Call around to your local propane companies and ask for a serviceman to do it for you.
