You need to post again with a little more detail. Does it stop on the way up? down? do the main lights flash? Does it do the same thing when you use the wall button?
The opener radio is not compatible with your homelink system. You need to buy a homelink repeater. Note: liftmaster and chaimberlain are the same, so if you see a reference to one of those names when searching for the repeater, dont worry, it'll work. As far as the second remote, check batteries. Then try programing again, using yellow button on the opener. Lastly, you can reset the programming and start over if all else fails. Hold down yellow button until light on button turns off. Good luck.
sounds like a power outage at some point. check batteries in remotes. re-program remotes to motor. get ladder, push square button on rear of motor then press button on remote. press remote again to check operation. repeat for second remote.
Since you do not have the code for your Frigidaire AC just aim remote control at AC press for 6 seconds and release SET key until ac open automatically, then press ENTER
You don't say but I am going to assume the door is stuck in the open position. Loosen the chain enough to relieve the tension on the trolley. Now run the opener until the door closes. While the door is closed locate the 'up limit' control on the side of the motor unit. Turn this control 2 full turns in the opposite direction of the arrow printed on the cover. Tighten the chain.
Look at the LED light next to the
SMART/LEARN button on rear of the motor unit. You may need to remove
a light lens cover in order to see it. If the light is flashing
rapidly this means you have a stuck button on one of your remote
controls. Take the batteries out of each remote control. When you
remove the batteries from the bad remote, the light will stop
flashing. This remote needs to be replaced.
If one of your neighbors remote
controls is inadvertently programmed into your receiver, you door
will open when their remote is activated. If this happens you will
need to clear out your receiver and reprogram your remote controls.
Press and hold the smart/learn button for 6 seconds or until you see
the small LED light near the button turn itself off. If the above
steps have been followed and the symptoms continue, there may be an
electronic short in either the wall control button or the receiver
logic board. In this case, remove the wall control wires from
terminals 1 and 2 on the motor unit. Should the symptoms persist
after the wires are removed, replace the receiver logic board. If the
symptoms stop with the wall control wires removed from the motor
unit, replace the wall control button, and the wires leading to the
wall control button.
How does everything look well? How old is unit? Did you push learn button for 10 seconds. Then pusj for 1 second and activate a remote button. lightbulb on motor should blink. if so, hit learn again for 1 second and push button on other remote. Do you have a LOCK or VACATION button. Make sure it is off . Is light on wall console blinking. you have remotes locked out.
The green button is not a reset it is the program button.
If you hold the button down for about 20 seconds it will erase all codes. Then, press and release the button - press and hold the button on your remote for about 10 seconds. the next time you press it it should activate the door. Repeat the 2nd step for all additional remotes.
The lock button on the wall control locks out all radio signals for vacations etc.
If the lock has been activated the green led in the wall control will flash - when the lock is deactivated the led stays solid green.
