Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
Posted on Mar 28, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sony KV 32FS13
Greetings!
Stand By light blinks several times and then the tv picture shuts off and then the sounds shuts off quickly therafter. ??? Thanks! Sandy
Anonymous
Level 2:
  • Expert 129 Answers
  • Posted on Mar 28, 2008
Anonymous
Expert
Level 2:
Answers
129
Questions
Helped
43173
Points
171
Good day.
Your system is encountering a hold down issue. Ussually, this is the absence of signals due to malfunctioning parts particularly in the vertical circuitry.it could Eigther be an IC, transistor or a defective resistor. However, it can sometimes be remedied by simply resoldering the loose components in the circuitry.
response is highly appreciated.
chris
2answers
I have a sony tv model kv-27v42 i have sound but no pictture and stand by light blinks what is the problem
How many times do this standby light blinks at a time of switch on? These blinks are fault indications. From the number of these blinks, you can get an idea about the faulty circuit section inside it. Count it. If you wish to get more details about the blinking codes to Sony TVs, check this link.
2answers
I have a sony trinitron kv36fs210, no sound no picture, stand by light blinks 5 times, tried unpluging for 24 hours, same problem. google searched problem,results found akb circuit problem, im not a tv...
It seems to be a problem to the power supply unit. I would suggest you have a look at the circuit board and look for capacitors that could have a popped up head. If you notice any, replacing it would solve your problem. I had the exact issue with my tv and fixed it that way. If you have any question please do not hesitate to ask, good luck.
1helpful
Sony Wega Kv-36XBR250 screen blinking
I have seen this flashing before, this could be an indication that the picture tube is weak, what happens is that if the white balance is off there is a circuit called akb it monitors the kathode of each gun and if they are not in balance it will attempt to balance it out. if it can't the picture will begin to flash, sometimes in some models the power light will blink 5 times. On some models the power light will only flash if the tv gives up trying to compinsate for white balance and shuts off compeletely. If you see the tv shutting off with 5 blinks then you know for sure it is time for a new set.
Sony 36" trinitron
check the horizontal output of your tv sets,if shorts need to replace it.
Sony Model KV32FS13, blinking lights.
check the horizontal output of your tv set,if short you need to replace it.
Red blinking light, SONY KV-32FS13
The 4 blinks usually mean a vertical deflection problem. If you can solder you should be able to repair this yourself. Let me know if you wish to attempt the repair and I'll provide more details and instructions.
Dan
1helpful
KV-36FS10 - No picture or sound Stand By Light blinks
5 Blinks usually means the horozontal circuit has problems and parts need to be replaced. unplug power to reset
Red light blinking
thear two ic that have gone bad this set need to go to a repear shop for this work to be done.
1helpful
2answers
Sony trinitron KV-32FS13
The HOT transistor is shutting it down. (horizontal output transistor)
it cost about 8.00 for the parts and 100 for the labor.
you will require help from a tech.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
