1997 Nissan Pickup Logo
Anonymous Posted on May 08, 2010
Leaf spring replacement
My PU has a definite tip in the right rear. I have seen this on many 1997 PU beds, but could never get Nissan to respond to the problem. I believe it has become obvious that it is the leaf spring.
Can a fumble fingered shade tree mechanic do this job?
Anonymous
Level 3:
  • Master 2,418 Answers
  • Posted on May 08, 2010
Anonymous
Master
Level 3:
Answers
2418
Questions
0
Helped
812690
Points
6999
Yes but you need two thumbs. Jack the truck and support it on the frame ahead of the axel so the axel can hang on its own weight. Remove the bolts and mount to the bad spring - remove the axel mount first, Let the axel sag and put something under the tire to help hold it. Remove the spring mount bolts to the frame and lower the spring out the rear. reinstall is the reverse --- BUT --- the new spring may not fit right in the spring mounts. Mount the front bolt first and then the rear - you may have to use a pry-bar and force the spring into the rear mount.
Testimonial: "Thanks for the solution. Your explanation is very clear and easy to understand. I feel confident that I can complete the job following your directions."
1helpful
Why when i turn on ac 1997 nissan pu. pulle?y squalls, will stop turning?
I really do not know what you are asking from what you wrote. if any pulley is squealing , it has to be replaced right away
For a 1990 chevy s10, the leaf springs on the right are on the ground, but everything is in tact, what do I need to do to get the bed of the truck back to normal?
  • Hi, I can help.
  • sounds like a band lost it's grip and the leafs slide back on you or the bands just broke and the leafs hit the ground.
  • You can stick a jack under the rear pumpkin and jack the truck up. You may find cutting or touching that big U-Bolt off will be easier than fighting the bolt itself.
  • Once you get the springs off you can attempt to reband them or replace the leaf springs.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
When I put the car in drive the back end bounces and their is a rubbing noise
Both of my big Ford trucks had to have the rear leaf spring mounts replaced. Look at your rear springs - if they are leaf style then check the rear mount points to see if they have broken loose. The springs end up moving way too much and it is not safe.
Rear spring bushes, (front of leaf spring) navara
Throw me an email at [email protected]
and I'll email you a copy of the Service manual for the Nissan Maxima 04, I have it as a WinRar compress document and also can be extracted using WinZip and so you'll ve able to see it as PDF to view and print out the only section u need, you'll have diagrams for all electrical to mechanical.....
The fast you do it the fast you'll get it....
Replacing shocks with air shocks on rear
The leaf springs should hold up the bed. The shocks generaly determine how much bounce there is when you go over a bump. In air shocks they can lower the vehicle and still keep the vehicle from bounceing a lot.
LOUD CLANGING NOISE
also check all your suspension bushings make sure they are all good. spare tire holder maybe? make sure none of the rear leaf springs are broken. also make sure all the bolts holding the bed down properly. make sure it isnt your tailgate either... could pretty much be anything. just make sure you bushings are good and everything is tight.
Problem with van leaning to the right in the rear. Can it be the leaf springs or leveling package.
Leaf springs can be weak in that side I've also seen the bushings in the mounting points of the leafsprings wear out causing a slight lean.
1helpful
When turning left/right or backing up my truck occassionally has a popping sound. I took it to the mechanics and they can't seem to find the problem. Everything was checked out fine. What is this?
#03-03-09-002B: Rear Leaf Spring Slap or Clunk Noise (Replace Spring Inserts) - (Jul 23, 2007) 999999995.gif Subject: Rear Leaf Spring Slap or Clunk Noise (Replace Spring Inserts) Models: 1999-2008 Chevrolet Silverado 1500/2500 Series Pickups 2000-2008 Chevrolet Suburban 2500 Series 2002-2008 Chevrolet Avalanche 2500 Series 2003-2008 Chevrolet Express 2500/3500 Vans with 8500 GVWR (RPO C5F), 8600 GVWR (RPO C6P) or 9600 GVWR (RPO C6Y) 1999-2008 GMC Sierra 1500/2500 Series Pickups 2000-2008 GMC Yukon XL 2500 Series 2003-2008 GMC Savana 2500/3500 Vans with 8500 GVWR (RPO C5F), 8600 GVWR (RPO C6P) or 9600 GVWR (RPO C6Y)
This bulletin is being revised to add model years and update the Parts Information. Please discard Corporate Bulletin Number 03-03-09-002A (Section 03 -- Suspension).
Condition Some customers may comment on a rear leaf spring slap or clunk noise. This noise is most apparent when the vehicle is operated over irregular road surfaces.
Correction Important: DO NOT disassemble the main pack on the leaf spring or remove the bushing from the spring.
(1) Insert -- P/N 15604067
(1) Insert -- P/N 15247030 Verify that the rear leaf spring inserts (1) are present on the leading and trailing ends of the overload spring (second stage leaf). The insert may have broken apart from wear and fallen out. If the inserts are not present, install new ones.
Important: On some models, the vehicle may have to be raised to allow the springs to separate enough so the insert can be installed.
Parts Information Important: Technicians should refer to the Parts Catalog when ordering the insert.
Part Number
Description
15604067
Insert, Rear Spring Leaf
15247030
Warranty Information For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
E5168
Insulator and/or Insert, Rear Leaf Spring - One or All - Replace
Use Published Labor Operation Time
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
999999994.gif WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© 2008 General Motors Corporation. All rights reserved
Bouncing rearend
Some leaf springs, when removed causes a bounce in the rear end when you forget to put them all back. You should try adding some leaf springs recommended from the manufractuer, or just look for the same parts from another model just the same as your vehicle. (tip from experience: match the leafs, and where they go.) for example: the small one will go with the other small one. I used the 2nd largest leafs and added them to my rear end, so instead of just one leaf stock there was two. if this solves your problem let me know.
Top Nissan Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Nissan Expert? Answer questions, earn points and help others
