Microsoft Xbox 360 Console Logo
Posted on May 02, 2010
How do i get windows media to work on my xbox
Anonymous
Level 1:
Problem Solver:
  • Contributor 17 Answers
  • Posted on May 02, 2010
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
17
Questions
0
Helped
7139
Points
51
To use your Xbox360 as a Media Center Extender, you must "link" the Xbox to your Media Center PC. Follow these instructions:
http://support.xbox.com/support/en/us/nxe/xboxlive/troubleshooting/networkhelp_mcxpc.aspx
This should only need to be done once. If you just want to stream music/movies from your PC, it should be auto-detected by the Xbox as long as it's on the same network. Make sure you have the latest version of Windows Media Player (version 11).
How to setup xbox 360 windows media centre
Instructions for Windows 7
1. Connecting the console to the network
Press the Guide button on the Xbox controller.
Go to the Settings page and select System Preferences.
Select Network Settings.
Select your wireless network or select Wired network if you are using a wired connection.
Select Test Connection to Xbox Live.
If the network connection status is Connected, go to step 2. Otherwise, select More information on the console and follow the instructions.
2. Delete previous connections (if necessary)
Launch Windows Media Center.
In the bottom section of the menu, click the down arrow and select Settings in the Tasks section.
Select the Media Extender section.
Select Xbox 360 Media Center Extender.
Select Delete.
Press 'Next.
Actions on the console. Delete previous connections
Go to the My Settings page and select System.
Select Computers.
Select Windows Media Center.
Select Disconnect.
Press the B button on the controller to return to the Xbox control panel.
3. Getting the installation key on the console
On the console, go to the Applications page, select My Applications, and then Windows Media Center. Tip. Don\u0027t see the Application item? You might need to update your Xbox 360 console software.
Choose Continue.
Record the 8-digit installation key.
4. Adding a console to Windows Media Center
Launch Windows Media Center on your computer.
Go to the Tasks section and select Add media box.
On the setup screen for the media extension, click Next.
When prompted, enter the 8-digit installation code obtained in step 3.
Click Next to complete the installation.
5. Launch Windows Media Center on the console
Go to the Applications page, select My Applications, and then Windows Media Center. When you first open Windows Media Center on the console, it will take some time to build the media libraries.
Done!
Xbox set up
If you have an Xbox 360 connected to a home network that also has a Windows Media Center, you can add your Xbox 360 as a Media Center Extender device so that you can enjoy the digital media on your Windows Media Center computer by using Xbox 360. For more information, see Xbox 360 online.
1. Turn on your Windows Media Center computer and log on to Windows. Verify that your computer is connected to your home network.
2. Turn on your Xbox 360 and verify that it is connected to your home network.
3. In Windows Media Center, on the start screen, scroll to Tasks, and then click add extender.
4. On the Welcome to Windows Media Center Extender Setup screen in Windows Media Center, click Next.
5. Press the Green Start button blank.gif on your Xbox 360 remote control or use your Xbox 360 controller to select the media blade.
6. On your Xbox 360, select Media Center.
7. On your Xbox 360, follow the instructions on the screen to obtain an 8-digit Windows Media Center Setup Key. Write down this 8-digit setup key. This is the key that you will use to affiliate your Xbox 360 with your computer that has Windows Media Center.
You do not need to download any additional software because the Extender functionality is built into Windows Media Center.
8. On the Enter the Setup Key screen in Windows Media Center, use the Windows Media Center remote control or keyboard to enter the 8-digit setup key that displays on Xbox 360, and then click Next.
9. Follow the steps in Extender Setup.
Several changes are automatically made to your Windows Media Center computer during the Extender Setup, including changes to the Windows Firewall settings. For more information about Windows Firewall, see Windows Firewall: recommended links. During this time, the Windows Media Center Extender service (which is named mcx2svc) starts on your computer, along with other dependent services.
If you have a firewall running on your computer that is not the Windows Firewall, make sure that the firewall software is set up to allow Xbox 360 to connect to your Windows Media Center computer as a Windows Media Center Extender. Some firewalls are already set up to allow Xbox 360 to connect to a Windows Media Center computer as a Media Center Extender. However, other firewalls will require you to make changes to how the firewall software is set up. For more information about which firewalls are already set up to allow a Media Center Extender connection, as well as information about how to set up other firewalls to work with a Windows Media Center Extender such as Xbox 360, go to the Firewalls and Media Center Extender article on the Microsoft website.
10. After Extender Setup has finished, in Windows Media Center, click Finish.
On the TV that is connected to Xbox 360, the Windows Media Center user interface appears. You can then enjoy live TV, recorded TV, pictures, music, videos, and other digital media on your Xbox 360 as you would in Windows Media Center. A new user account named mcx1 (by default) is automatically created to use the Extender.
Please see http://windowshelp.microsoft.com/Windows/en-US/Help/8076aff3-16ec-4751-9f57-d36e0ff407201033.mspx#EPD for more info.
Thanks and hope that helps!
Les
tip
Configure XBOX with Media Center
Windows Media Center setup on your Xbox 360 Begin by connecting your Xbox 360 to your home network. The Introduction to Home Networking guide on the Xbox website will provide information if you're setting up a network for the first time or if you need some guidance for adding the Xbox 360 to your existing home network.
Once your Xbox 360 is connected to your network, begin the Windows Media Center setup process by pressing the green button on your remote control (if you have one), or use your game controller to select the Media Center option from the Media tab in the Xbox 360 on-screen menu.
You are asked if you want to connect your Xbox 360 to a PC running Windows Media Center in Windows Vista. Select the Media Center option to continue.
Once your Windows Vista-based PC has been detected, your Xbox 360 will display an eight-digit code. Write down this code on a piece of paper, and then go to your Windows Vista-based PC.
Note: When connecting to a Windows Vista-based PC, you do not need to select Continue or download additional software.
Add your Xbox 360 as an Extender to your Windows Vista-based PC Important: During the setup process, the Windows Firewall is automatically configured to enable your Windows Media Center Extender to connect to your Windows Vista-based PC. If you're using extra security software that includes a non-Microsoft firewall, you may need to manually configure your firewall to ensure a successful setup and connection.
With your eight-digit code in hand, begin by selecting Windows Media Center from the Start menu in Windows Vista. From the Windows Media Center menu, select Tasks, and then select Add Extender. This will begin a simple, step-by-step path that will add your Xbox 360 to your Windows Vista-based PC. During this setup process, you will be asked to provide the eight-digit setup key you received from your Xbox 360.
Click through this preview of the setup to familiarize yourself with the process.
The Extender Setup screen provides an introduction of the steps you'll go through to add an Extender to your Windows Vista-based PC. Click Next to start the process.
Enter the eight-digit setup key you received from your Xbox 360 (the one that you wrote down on your piece of paper, right?), and then click Next.
The setup process will need to make changes to your Windows Vista-based PC settings to establish the connection to the Xbox 360. Click Next to continue.
Review the information provided about Away Mode. Make your selection, and then click Next.
The setup process will ask if you would like to share media with the Extender. Select Yes (recommended) to share media folders, and then click Next. If you are using User Account Control, you'll see a User Account Control dialog box that will seek your permission to run the Windows Media Center Extender Configuration. Select Continue to grant permission.
Your PC will now go through the remaining steps to configure itself and establish the connection to your Xbox 360.
That's it! You're done! When you're finished with the PC setup, go back to your Xbox 360, and start enjoying access to all of the digital entertainment stored on your Windows Vista–based PC through your Xbox 360.
Optimize your home network The quality of your entertainment experience, especially video playback, is dependent on having a reliable and high-performance home network. To help ensure the best performance, we recommend that you run the Windows Media Center Extender Network Performance Tuner during the setup process on your PC. The Network Tuner provides very specific feedback on your network, as well as tips to solve any potential problems.
You can click through the preview of the Network Performance Tuner to familiarize yourself with the process.
The Network Performance Tuner runs diagnostics on your home network and provides feedback on potential issues that would make your Windows Media Center experience less than optimal.
When analyzing the network, the Network Tuner provides specific feedback based on all of the components connected to your network.
The Network Tuner provides feedback on the types of media that your network may have trouble handling effectively and suggests corrective actions than can help to solve the problem
The Network Tuner also looks for performance issues related to how your network is set up. In this case, the fact that the Windows Vista-based PC and the Xbox 360 are both connected wirelessly to the router may cause performance issues. You'll only see these warnings screens when the Network Tuner has detected a problem.
Real-time feedback is offered through the Network Tuner, so you can see if the adjustments you make to your network improve the performance.
Regards,
Shrey
on Dec 17, 2009 • Computers & Internet
Im trying to set up my windows media player but it wont play the songs
is it windows media player or is it windows media center? if media player then make sure both xbox and pc are on and that you have file sharing turned on in your network sharing options and make sure your xbox shows up as a media extender on your pc
if media center repeat same steps
How do i connect my 360 to the computer
I had this same problem and found this great video on youtube.
go here:
http://www.youtube.com/watch?v=BaKgCYkSCjc
over 175,000 views
if you click the drop down on the info you'll see the step by step instructions.
STEP 1
If you were previously using your Xbox 360 with a Windows XP Media Center Based PC, you will need to remove existing connection. Otherwise skip to step 2.
At the Windows XP Media Center PC
Click Start, point to All Programs, point to Accessories, point to Media Center, and then click Media Center Extender Manager.
Select your Xbox 360 and click Properties.
Click Remove.
Click Yes to confirm removal.
At the Xbox 360
On the Xbox 360, go to My Xbox and then System Settings, then select Computers.
Select Windows Media Center, and then press the A button.
Select Disconnect.
Press the B button until you return back to the System Settings.
STEP 2 Gather Setup Key from Xbox 360
Press the Media Center Start button on the remote or go to My Xbox, then select Windows Media Center.
Advance through the on-screen instructions to obtain the 8 digit Media Center Setup Key. Write this key down.
STEP 3 Add Extender
At the Windows Vista-based Media Center PC, launch Windows Media Center. Select Start, Windows Media Center.
Select Tasks, Add Extender.
When prompted, provide the 8 digit setup key you received at the Xbox 360.
Complete the Extender setup.
STEP 4 Print the Media Center Quick Reference Guide
Can i get windows media center without a pc?
No, unfortunately, you need windows media center on your pc to stream videos, music, and pictures from your pc to your Xbox. It kind of sucks I know, as windows media center isn't the most accurate of programs. Has a tendency to loose data. Also, since it is a windows platform, your Xbox will have issues playing certain types of media files. Hope this helps.
2answers
I cannot link my xbox to the pc or window media centre.
go to microsofts download site. And get a program Called XBConnect. Or xbox connect.
Thankyou For Using Fixya.
Mike @ compurepair.
Xbox 360-computer?
To connect the Xbox 360 console to this computer, you must be running Windows XP Service Pack 2, Update Rollup 2 for Windows XP Media Center Edition 2005, or Windows Vista.
To obtain your setup package or instructions for connecting your Xbox 360, select the version of Windows installed on this computer from the following list.
To determine the version of Windows XP Media Center Edition that you are running, follow these steps:
  1. Start Media Center.
  2. On the Settings menu, click General.
  3. Scroll down, and then click About Media Center.
  4. Click Software Version
    The version number of Media Center you are running is displayed.
To determine the version of Windows XP that you are running, follow these steps:
  1. On the Start menu, right-click My Computer, and then click Properties.
  2. On the General tab, under System, look for the version of Windows that you are running.
8helpful
2answers
Movie Formats To Work With Xbox 360
As you may have heard, with the Xbox 360 Flash Fall 2006 System Update they are adding support for WMV video playback from new sources. Videos can be streamed from a PC running Windows Media Connect, Windows Media Player 11, or the new Zune client player, and can also be played from Optical Disc and most USB mass storage devices. For all these sources, only the WMV video file format and codecs are supported. How do I know if a video file will work on the Xbox 360? Currently only the Windows Media Video (WMV) file format and codecs are supported. If you have a file with a ?.wmv? extension, then the odds are pretty good that it will work. Technical details on the types of files we support can be found at the end of this post, but the easiest way to find out if a file will work or not is to just try it. Hopefully after you click play the video will show up on your display, but if the content is not supported you will simply get an ?Unplayable Content? message blade from the side of the screen and then be returned to the Video blade. How do I create videos that will play on my Xbox 360? Windows Movie Maker, a standard feature of Windows XPSP2, will output WMV video files compatible with the Xbox 360 console. Either use the default settings when you finish a movie and click ?Save to my computer,? or just make sure that the output video format you select shows the file type as ?Windows Media Video (WMV).? Videos will usually look best when they are closest to the original resolution that they were created with. Try to create video files at least 360 pixels high in vertical resolution in order to minimize content upscaling on the console. If you decide you want finer control of the output video file format, download a version of Windows Media Encoder (http://www.microsoft.com/windows/windowsmedia/) and then start encoding away. Optimal size and bitrate settings will vary depending on the source material you are encoding. As a general guideline though, 1.5 Mbps is a typical bitrate that should be suitable for most standard definition content, and 8 Mbps is a common bitrate for high definition content. Can I get more technical details about the kinds of files you support? WMV video files with the extension ?.wmv? are stored in a generic file container format known as ASF. ASF files can contain many different types of codecs within them. Xbox 360 supports most common WMV video codecs, as seen in the following chart: Supported Video Codecs: Name FourCC Windows Media Video 7 WMV1 Windows Media Video 8 WMV2 Windows Media Video 9 WMV3 Windows Media Video 9 Advanced Profile WVC1 There are some files with ?.wmv? extension that may play on a PC, but are unsupported on the Xbox 360 console. Windows Media Screen, Windows Media 9 Image (Photostory), and some older Microsoft codecs are unsupported, as seen in the following chart: Unsupported Codecs: Name FourCC Microsoft MPEG-4 Video Codec V3 MP43 Microsoft MPEG-4 Video Codec V2 MP42 Microsoft MPEG-4 Video Codec V1 MP41 Windows Media Screen V9 MSS2 Windows Media Screen V7 MSS1 Windows Media Video 9 Image WMVP Windows Media Video 9 Image v2 WVP2 ISO MPEG-4 Video V1 MP4S Anamorphic content with nonsquare pixels is currently unsupported on Xbox 360 console, and will be displayed as if the pixels were square. If you want to play such content on your console, it is recommended that you re-encode the content in a square pixel format.
Top Microsoft Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
ELECTRICKSUSA
ELECTRICKSUSA
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
