MSI GX630-028US Notebook Logo
Posted on Apr 29, 2010
I cannot turn on wireless capabilty using fn and wireless symbol. Is there any other way of turning wireless capability on?
Anonymous
Level 1:
New Friend:
  • Contributor 32 Answers
  • Posted on Apr 29, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
32
Questions
0
Helped
9382
Points
58
Follow these Steps :
1> Go to start
2> Click on RUN
3> Type SERVICES.MSC
4> New Window will appear
5> Go to bottom of the page
6> Select Windows ZERO Configuration
7> If it shows Manual then Right click on this service
8> Go to properties
9> You will get START TAB
10> Click on START
11> Click APPLY and then OK
12 > Select AUTOMATIC where its shows start service MANUAL
Now try to connect with wireless connection
If still its not working then folow these steps .
1> Go to Control Panel
2>Click on Network Connections
3>Right click on Wireless network Connections
4> Click on properties
5>New Window will pop up
6> Select Wireless networks tab
7>Check very first option which says " Use Windows to configure my Wireless Settings
8> click on Apply
9> click OK
now try to connect with wireless
How do I turn on wireless capability
To enable or disable wireless functions, you must use the Hot Key combination of "Fn" + "F8". This means to press and hold the "Fn" key (near the windows key), and the press the "F8". This is a toggling function. Each time you press the key, it will turn on or turn off the function. Look for the Wireless Light to ensure that the wireless activated.
Can not turn on wirless capability dell inspiron 1545 windows 7
first,, press FN + F1 or FN + button with antena symbol...then go to network and sharing centar//change adapter settinds// choose wireless adapter with right click // connect and there you are
I have 2 computers with wireless but the msi net will not connect it telling me wireless capabilty is turned off and i dont know how to turn it on
You need to turn it on:
Look for a switch for turning it on. It will be having an icon look alike antena symbol.
If the model of your laptop does not have any switch then look on to the keyboard carefully observe the keys and look if you can find a key with a symbol of antena on it.
Usually F2 swutches on the Wireless or sometimes combination of Fn+F2 switches it on.
Try this and let me know if this works out for you.
The wireless capability won't turn on, wheres the switch? advent 5303
I guess you are asking the Wireless switch on your Advent Laptop.
If there's no dedicated switch or button on the system (the symbol looks like multiple waves or tower), then the switch should be Fn+F2. You have to press Fn+F8 simultaneously to activate the wireless. Pressing the keys again will deactivate the wireless.
If you need further help, let me know.
3helpful
I can not work out how to turn the wireless conection on.advent 7070.what keys do i use
To enable the Wireless LAN Fn + F2
usually the wifi function key has the universal antenna symbol with radio waves emanating from it.
The manual says the other hotkeys are:
Fn + F2 - Wireless LAN
Fn + F3 - Standby
Fn + F4 - External display
Fn + F7 - Reduce brightness
Fn + F8 - Increase brightness
Fn + F9 - Play / pause media
Fn + F10 - Stop media
Fn + F11 - Media previous chapter
Fn + F12 - Media Next Chapter
Fn + scroll - Scroll Lock
1helpful
How do i turn the wireless capabilty on? my internet was working fine i restarted my laptop and now can not pick up my wirless, its saying that my wireless capability had been turned off, how to i put it...
Look for a WiFi button to ensure it isn't off. If it isn't, then go to the Control Panel and go to Device Manager (Hardware Manager in Vista) and make sure the device disabled. Right click it and choose Enable. Should pick up your wireless.
33helpful
4answers
My wireless capability is turned off
How do I turn on the wireless capabilities on my MSI laptop?
My wireless capability button is broken on my gateway laptop.
ok so my wireless switch wont turn on i have a new gate way laptop was working fine yesterday
Wireless radio adapter
if ur sure that that it is the fn and f2 that u have to press simultaneously to turn on wireless capabilty. Make sure u press it long enough
Right click on wireless network connection item in ur system bar and goto view available wireless connection and check what message is displayed there
If it still says that " No wireless network were found , make sure wireless switch is on "
Contact COMPAQ
If ur not sure whether it FN F2 , then try to FN & F5 or FN & F2
Top MSI Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
