20 Most Recent Dell Inspiron E1405 Notebook Questions & Answers
Call Dell customer support phone number 1-800-204-4427 to get online help for technical problems related to Dell computer, laptop, printer, scanner and tablet Dell Laptop Support Phone Number 1 800 204 4427 Tech Help
Dell Inspiron... | Answered on May 18, 2017
Trinity Rescue Kit from Sourceforge.net Can reset it
Dell Inspiron... | Answered on Oct 19, 2016
If it turns black again, try to check first if it's just the LED's that are defective. If you push the monitor 40 degrees down, and you can see very faint display from that angle, then it's probably that the LED's are the culprit, and you can have it replaced for a less price.
Dell Inspiron... | Answered on Jun 16, 2015
If the drive has not crashed ( Not Useable ). You may be able to connect the Hard Disk to another machine and get the data off.
You will need to install to a computer as a secondary drive. USB to Harddisk Adapter.
Dell Inspiron... | Answered on Nov 25, 2013
Pull up the display settings - and check the gamma for the video card.
Dell Inspiron... | Answered on Nov 21, 2013
What is the problem
Dell Inspiron... | Answered on Nov 16, 2013
yes, get a volt meter and carefully place the leads on the output side of the charger....see if it's delivering the 8.5 to 12 volts needed....per the "voltage label specification" of your charger.
Dell Inspiron... | Answered on Oct 31, 2013
I would go to Dell.com, navigate to the drivers for your laptop and download the latest driver for your WiFi card. To install the driver, click on the file.
Dell Inspiron... | Answered on Oct 26, 2013
That usually means that you're battery has exceeded it's life expectancy and needs to be replaced. Could also mean that the circuit on your system board that charges your battery is defective and not charging your battery. Remove the battery and use the AC adapter and see if the the laptop turns on with out the Yellow LED flashing.
If so, then you either need a new battery or new system board. If the latter, might be chwaper to buy new computer.
Dell Inspiron... | Answered on Aug 30, 2013
James,
You will need to either reinstall Windows or you can search the internet for password recovery software. There is usually a fee on some of these sites. Dell does not have any generic passwords to help you get back into Windows.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Dell Inspiron... | Answered on Jul 29, 2013
i can send you a link for software to take the passward off do you no how to burn an iso image if so i will send you the link
Dell Inspiron... | Answered on Feb 28, 2013
go to resolution and lower it to 800x600 by right clicking in desktop or try a new svga video cord
Dell Inspiron... | Answered on Feb 27, 2013
DST (Drive Self Test) failed. this simply means that the drive is no longer stable. If you are unable to boot to windows or safe mode and this is the error you get you might need to do a low level format if you still want to use it or do a debug script then repartition and re-format the drive.
The Low-level partition - will reinitialize your drive to the factory settings.
Debug Script - removes DOS and non-DOS partitions on the hard drive. It also allows you to convert a drive from an incompatible partition structure to one that will work with FDISK.EXE such as, converting Linux partitions to MS-DOS partitions.
For you to use the Low-level format and to completely wipe out HDD data. Use the format software from http://www.killdisk.com, download the CD ISO image , burn to CD, ad boot from CD , the rest can be found in the menu.
In using the debug script use this :
Insert the boot diskette that contains the Debug command into the respective drive.
Restart the computer.
A black screen with Microsoft Windows® 95 Startup Menu will appear. Press the <5> key on the keyboard followed by the <Enter> key. The boot process will conclude with an A:\> prompt, followed by a blinking underline (cursor).
From the A:\> prompt, type the following commands and press the <Enter> key after each command:
NOTICE: Performing the following will remove all data from your hard disk drive.
NOTE: Type the bolded text only (the debug prompt is a dash). You will receive an error if you type anything other than the bold text. The non-bolded text represents the system response that will appear after typing each command and press the <Enter> key.
debug
-F 200 L1000 0
-A CS:100
xxxx:0100 MOV AX,301
xxxx:0103 MOV BX,200
xxxx:0106 MOV CX,1
xxxx:0109 MOV DX,80
NOTE: Type 80 for the Main hard drive - HD 0, or type 81 for the Second hard drive - HD 1.
xxxx:010C INT 13
xxxx:010E INT 20
xxxx:0110 (Leave this line blank and press the <Enter> key)
-G
The message, Program terminated normally, appears. Turn off the computer by pressing the power button.
On the next startup the hard drive must be partitioned and formatted.
Hope this helps to save your drive.
Dell Inspiron... | Answered on Dec 26, 2012
If it's the drivers for the laptop, you can find them at Dell's support site. If it's the drivers for the monitor (some monitors need their own drivers in order to work) you can find them at the monitor manufacturer's site or driverguide.com
Dell Inspiron... | Answered on Dec 21, 2012
Safe Mode is only for troubleshooting and internet may not work, because Windows loads with minimal drivers. Hence hardware will fail to load.
There is a Same Mode with Networking option.
Dell Inspiron... | Answered on Dec 09, 2012
You can remove or change the Window's User or administrator's password. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :- http://www.hirensbootcd.net/ http://67.20.82.163/
Dell Inspiron... | Answered on Oct 05, 2012
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Dell Inspiron... | Answered on Sep 09, 2012
Dell Inspiron E1405 Notebook Logo
143 questions posted
Clive
Clive
Alun Cox
View Most Popular
Inspiron Dell
  • Inspiron Dell
Most Popular Question
in dell laptop model inspiron e1405 bios
  • Computers & Internet
