SOURCE: intermittent problem no sound
Double and triple check your connections. I soldered my connections on a speaker a little while ago and I found out that it only looked soldered and it was alittle loose and would cut out. Also you could check a site out, installdr.com. You should be able to find out the wire colors for you speakers there. Although I don't think that, that will cause a big problem. If you are listening to music at loud volumes, I would also recomend an aftermarket amplifier. It adds so much more that a factory amp can. Just food for thought. Good luck.
-Andrew Hawkins
SOURCE: I have a 2001 Ford Expedition Eddie Bauer rear AMP doesnt work?
there should be fuses near your amp and near the battery
SOURCE: wiring after market stereo to factory wiring equipt with factory amp
you have to get the cable that conects your factory deck harness to the aftermarket deck, and that will allow you to use your factory speakers and amp, the wire harness is availiable at canadian tire or any stereo shop
SOURCE: what is the wiring color code for a 2005 ford expedition radio
use google. i did and i got this
Car Radio Battery Constant 12v+ Wire: Light Green
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: If equipped, the factory amplifier is located behind the trim panel on the right side of the cargo area.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): Dark Green/Orange
Right Front Speaker Negative Wire (-): White/Light Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
SOURCE: removed factory stereo and installed after market
Have a look at this link, may help.
http://www.the12volt.com/installbay/stereodetail/710.html
