If someone would be so kind to explain how does one insert the parts in the head after removal, as there is no diagram for this.If someone would be so kind to explain how does one insert the parts in the head after removal, as there is no diagram for this.
You can't post conmments that contain an email address.
Here is the link to their online store where you can find parts and also new sets.
http://www.conair-store.com/category.asp?NAV=PERSGROOM&HDR=GROOMING&trk_src_ss=CONPAYPCWEBMACSS'PPC'ADW'conair%20hair%20trimmer
Thanks
You do not need to unscrew anything. Instead, simply take the beard trimmer (with the beard shaving blade still screwed on) in your hand, with the power button and "CONAIR" logo facing you. Then, put your thumb under the shaving blade and apply force to pop it off. So, the shaving blade, and the top part of the unit that it's screwed into will simply pop off. Then, you simply align the nose/ear hair attachment, and snap it in to the beard trimmer unit.
Conair trimmers are only good for about a year and they are hard to put back once you have messed with them. does your blade pop off or does it have two phillips screws holding it in? If you take the blade off completely you should see two arms that are in there, you have to place the blades back on correctly and hold them together while putting the screws back in. be very careful not to tighten the screws too much. Oil your blades with 3-1 oil and then turn them on. adjust the trimmer and see if everything is level, if it is try cutting withem and see what happens. If the motor sounds good but the blades are pulling your hair rather then cutting it then you need to replace your trimmers because your blades are daul.
Go to a Sally Beauty supply and purchase a can of the blade wash. It is relativly inexpensive. You dip your blades into ths special wash and it cleans the blades and keep them sharp and is safe. DO NOT take the heads apart, Let the pros do that but blade cleaner you immerse them in and trust me it is what we pros use.
There should be 2 phillips head screws on the underside of the cutting blades.loosen them enough to where the 2 cutting blades are able to move freely then take some 3-in-1 oil and apply some in between the blades and tighten the bladesback down.Turn the cutters on for about 30 seconds and they should be good to go.Rate me FIXYA! if this helps! GOOD LUCK.
