Fuji FinePix 3800 Digital Camera Logo
Anonymous Posted on Apr 15, 2010
I'm trying to upload some pics from the camera,fujifilm model 3800 Finepix to my laptop,Latitude/d600 with Xp and I thought I down loaded the corrrect software and drivers. I am not getting anywhere.
  • FIKRET UNALIR
    FIKRET UNALIR May 11, 2010
    Please clarify your problem. I could not understand exactly.
Muntejaya Ginting
Level 3:
  • Master 10,422 Answers
  • Posted on Feb 19, 2011
Muntejaya Ginting
Master
Level 3:
Answers
10422
Questions
Helped
2470449
Points
19564
Lines in pictures?
It could probably be the image sensor of your camera.
Trying to upload pics with my card reader and it says the pictures aren't supported, so they won't upload...any ideas why? Just uploaded from another camera
sir the memory card that you have in your camera do not allow pics to upload.Because the card that we put in the camera only allow picture to download from it.It will not allow pics to upload to it.If you want to upload pics to your camera try after putting a micro SD card.For that you should buy a micro SD adapter.After putting micro SD into that adapter you can put that into your camera.Then it will allow both uploading and downloading.
Whenever I attempt to upload pics from my finepix z70, all I see is a gray screen that says USB. If I transfer the card to another camera, I can upload all the pictures, but not the videos and use the...
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Lost software disk for the Fujifilm finepix s700, can't upload?
If you are using Windows XP the Z10 should be a plug and play without using the Fuji software. If you need a link to the software, this ought to do it. http://www.fujifilm.ca/x13918.xml
2answers
Bets and easy way is to doenload from the Fujifilm Website, its free or contact @ 033- 32516697
Problem with uploading photos from fujifilm finepix s1000
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
Aug 13, 2008 • Cameras
Help to download pics
hi there sing
you can still download the pics from your camera unto your lappy. if your using XP. this will be automatic since your lappy will detect that the camera is insert then you can either manually copy the pics or use the wizard to copy the pics. this is the same for vista.
Cannot upload pictures from camera to pc
Assumin the computer is a Windows ME/2000/XP/Vista
Remove all camera software from the Computer.
Plug camera in. make sure it is set to Upload.
Windoze will detect it and put up the Scanner/Camera Wizard
Let Windoze do the work
Top Fuji Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Fuji Camera Expert? Answer questions, earn points and help others
