Hi this could be one of a couple of problems , either the needle on the Gage has stuck to the empty side of the Gage try tapping it to see if it will dislodge itself, or the sender unit in the fuel tank is stuck at the bottom , you can however try to see if it will release itself by banging on the bottom of the fuel tank with your hand ( no hammers required), this should dislodge it from where it is, if this does not work, check the wires coming from the top of the tank to see if one of them has come off or is broken....hope this helps
