Microsoft Xbox 360 Console Logo
Posted on Apr 07, 2010
My xbox 360 is playing in black and white
Tried changing the pal sttings but one just plays black and white and the other pal setting wont play games
Anonymous
Level 1:
New Friend:
  • Contributor 32 Answers
  • Posted on Apr 07, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
32
Questions
Helped
3950
Points
79
Which TV Output do you have, mabye when you changed that PAL setting you screwed it up, and it made it black and white. If its an HD Screen make sure your switches and all of your plugs are plugged in.
My xbox will only play in black and white i tryed changing it to 50 hzs coluar but i cant play games
this will happen depending where you got your xbox from and where you are located.
There are multiple types of TV signals. Typcially two are used NTSC and PAL. If you have a TV and are in a country that supports PAL and you purchased say an XBOX from america then you will have a black and white screen or no game at all. Same thing goes if you are in america and say purchased the xbox on ebay from a perosn in europe. You will get a black and white game cause your TV is NTSC and not PAL.
Many game units will support BOTH signals but are locked to a signal of the region the console was intended for sale on.
My xbox is black and white i changed the pal 60 to pal 50 and my game isn't supported
Hi a lot of games on xbox need pal 60 to run properly, bought my lad a xbox and then had to buy him a new tv as well because old tv was only pal 50 and most of the games he wanted to play wouldn't work with it, the tv carnt keep up with the xbox graphics!
PAL 60 Display Problem
Greetings,
Please go through the Website link mentioned below.
http://support.microsoft.com/kb/917304
Please let me know if you have any issues.
Regards,
2helpful
Wont play on my xbox 360 new hour of victory game says wrong region wont play
This sadly means the game and Xbox 360 console aren't the same region. (Rather the game is region locked, meaning unless you have a Xbox 360 that plays those regions, the game is non-playable because the console can't read the disc.) There really isn't any solutions for this, other than take the game back to the store and ask for your money back because the region of the game doesn't play on your Xbox 360. Always make sure when buying Xbox 360 games that it's the right region code. (Or that it's a region free coded game) There are a few games like that out, one being Borderlands for example.
If it says PAL on the cover of the game for example, the game covers most of Asia, Africa, South America, Australia, New Zealand, and most of Western Europe. (List of common PAL regions can be found here.)
There are a few other region codes for games, so you better make sure you are buying the ones for your region.
Hope this was of some help.
Screen is black and white but plays fine
try a different tv set as it could be setting on you tv which is causing the black and white.
Xbox 360 arcade pal game read error
You will get this error when your laser is in need of replacing. The other message you will get is open tray. If your system will play regular movie dvd's but not games then replace the laser. You can find them pretty cheap on ebay.
Black and white screen on tv when i play my x-box 360
Have you tried adjustign the mhz settings ie: change from 50mhz to 60 mhz as some games will show up in black and white if you have the xbox set to 50 mhz
5helpful
3answers
Alba tv plays xbox 360 games in black and white
This is an easy fix.
Within the xbox, goto system settings, and chnage the display output ot pal 50.
Problem solved!
2answers
Black and white picture
do u have your 360 display settings at 60hz if so the tv might not be compatiable with a 60hz signel go to display setting and drop back to 50 hz and colour may show it self but remember some games wont play in 50hz if this is the case try find a ntsc to pal converter
2helpful
5answers
How to change from PAL-50 to PAL-60?!
i have a xbox 360 and a television that opperates at PAL-50
my xbox is telling me, to play a game i must operate at PAL-60.
when i change the xbox settins to PAL-60 the televison goes all fuzzy, can i fix this.
Top Microsoft Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
ELECTRICKSUSA
ELECTRICKSUSA
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
