If you really forgot what was the lock code, lease perform hard reset on your phone. Please be advised that doing a hard reset will wipe out all files on the phone including the lock code.
1. If you forgot your master codeand your phone is not currently locked, you will need to reset your phone. Onlya hard reset is necessary in this case. Note that before you reset the phonemake sure you back up all your information, as this reset erases everything onthe phone and makes it brand new. Simply dial: *#7370# It will demand fora security code; put in this code - 12345 , then ok. The phone will restart,while the reset takes place. Once this is done your new security code will be12345 YOU CAN ALSO TRY *#7780# Hope this helped,
try hard reset..that will be remove all and that phone password Hard reset is better for solved that problem.. First swith off you phone,after swith off,click *,3 and green key(call key)---->hold, After to hold that key,now click power key to swith on --->*,3 and call key must hold... Try it :)
Hello. You can do a master reset on you phone simply by going to your phone menu and finding Settings\General\MasterReset. You may loose some unprotected files so if that is important to you you may want to back up all of your files on your memory stick first. The other option is to go to your phone store and have them do it for you. Good luck with it.
try to reset the phone, for the hard reset on the phone, you need to take off the battery of the phone then remove the sim card. After that place the battery back without the sim, please enter *2767*3855#. Just a reminder everything will be deleted on the phone, it will restore back to the factory settings. If this procedure would not help the phone needs a reflash.
Ok, THIS WILL WORK! It worked on my W580i and it wasn't even supposed to. FIRST! Download (8.8MB) XS++ From HERE:http://forums.se-nse.net/index.php?showtopic=16338 SECOND! No install. It just runs. Make sure you have ALL drivers for YOUR phone. That should be under the bettery. Under model... or something like that. HERE! http://www.nodevice.com/driver/company/Sony_Ericsson.html
Take your phone, turn it off. Start this program and click on connect. You'll have 30 seconds to plug your phone into your computer and HOLD C The entire time! (the delete button or 2). If connected, then click at the button: GDFS. There will be a phone lock reset to "0000". Click it. It will take no more than 45 seconds. I promise. Unplug your phone, and vuala! If your phone won't turn on, try pulling out the battery, putting it back and trying again. This program is also good for flashing phones, and putting flash menues on your phone. Also unlocking it and debranding it. GOOD LUCK!
i changed my unlock code and set it so my phone locks as soon as you turn it on. But I forgot the code.... And i cant acess anything in the phone without it.. Help me plzzz
