Kenmore 31912 Progressive Direct Drive Bagged Upright Vacuum
Problem for Kenmore 31912 Progressive Direct Drive Bagged Upright...
Kenmore Progressive Direct Drive Upright - noise and bad suction
By seamus_boss on Mar 15, 2008
Working great, then one day, a horrible sound started coming out of it. When you turn it on, it sounds fine. It's when you put it to work the sound comes out (the tighter the suction gets, like when you put your hand over the opening of the hose, the louder it gets). made sure the bag was ok, nothing blocking the hose or opening. Figured out the sound is coming from this small air filter type opening on the back right behind the hose when it's wrapped up. Loud vibrating sound. If you put something over that small area, sound goes away. Also, the vacuum is hardly picking anything up, which is very frustrating. Any ideas? Very expensive vacuum, only used probably 8 times in 6 months before problem started.
Comments:
Mar 18, 2008
- thanks for the thoughts!
Yeah, the hose suction is great. right now i'm actually using the extender tools to vacuum, so that works fine. So, something must be wrong near the roller area, just not sure what. And that loud vibrating sound on the back right occurs whenever the suction is being fully used (like when using the vacuum upright, or when you put your hand over the hose). I wonder if the sound and the lack of suction when upright are related. Just not sure how to troubleshoot.
Thanks!
Same Problem
Jan 19, 2009
-   I have the same problem. Seems like something is blocked, but can find no block. Help! I guess the noise is coming from some sort of overpressure valve that kicks in for some reason.-   N in Texas
Sep 01, 2008
-   Same problem!!! But it started after my boyfriend vacuumed up a big piece of cotton from the inside of a sofa cushion.-   minan
Aug 26, 2008
-   What can we do when a two year vacuun cleaner starts making noise and rollers do not turn just out of no where?? Help, please-   Guest
Aug 16, 2008
-   loud sound when turn on upright. has new bag, stretched out the hose, etc., but still noise. i did not replace filters, but brushed them off. ???? -   marjumac
May 08, 2008
-   I have this exact same problem - I checked the hose and it is clear - and the filter looks fine - where is the dirt inlet at to check it??-   MomToTwo
Best Solution
posted on Mar 18, 2008
Helpful)
reddevil6
Rank: Guru  Kenmore Expert
Rating: 88%, 1792 votes
How is the suction at the end of the hose. If it is ok, then the problem is by the brush roll. The dirt inlet maybe clogged. If no suction, then either the hose hstill has a clog or a bad filter preventing air flow.
Was this helpful?
Yes
No
Solution #2
posted on Apr 08, 2009
Very Helpful)
mikeandmegan
Rank: Apprentice
Rating: 100%, 1 votes
Had the same problem tonight. Took the entire thing apart only to find there was a much simpler solution. Check the small hose that runs from the brush rollers where the longer hose (on the back) attaches to the side of the vacuum. Easiest way to do this is to lay the handle down and stick something (coat hanger worked good) through it until it comes out of the head. I found a pretty good sized fuzz plug in mine. As soon as I removed it, everything worked great again - and no noise!
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #3
posted on May 06, 2008
Not Rated)
wingscfs
Rank: Apprentice
Rating: 0%, 0 votes
I have a Kenmore upright bagless vacuum. When I start it there is no sound but the light comes on.
Was this helpful?
Yes
No
Popular Solutions for Kenmore 31912 Progressive
Questions and Unsolved Problems for Kenmore 31912 Progressive
Do you recommend Kenmore 31912 Progressive Direct Drive Bagged Upright Vacuum?
Answer
Answer
on my Kenmore Progressive Dircect Drive upright bagged vacuum, one day the motor was working hard,... (More)
Answer
I took my vacuum cleaner apart to clean it because it was clogged inside and now I am having trouble... (More)
Answer
I'm not sure if it is a worn belt or a worn agitator as mentioned in the instruction book but I'm... (More)
Answer
I don't know how to get the vacuum apart to get to the connection inside the vacuum.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Vacuum Experts
Top Vacuum Repairmen
in , DC
(502) 348-4900
Authorized Dyson and Miele Service center. Work...
VACUUM SOLUTIONS
(877) 822-8227
When you browse our large selection by vacuum...
Vacuum Cleaner Shop
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
