Computers & Internet Logo
Posted on Mar 29, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where can i download a driver for my free agent go 1 tb external drive from seagate
Azrael SRL
Level 3:
  • Master 11,800 Answers
  • Posted on Apr 04, 2010
Azrael SRL
Master
Level 3:
Answers
11800
Questions
0
Helped
2567096
Points
35672
Free Agent Go is nothing more than a hard disk in an external case. From the pc's point of view it's just a generic Mass Storage device. As such it doesn't need a  special driver. Just plug it in and it should appear in My Computer as another partition/disk. After that it can be used just like any other partition. The only precaution is to always click the Safely Disconnect icon before unplugging it.
I need Seagate service center in Metro Manila. My 2 TB Free agent go flex external hardrive use to be working well. Recently the lights went off and can not be detected now.
Take the drive out he caddy and plug it into another computer to see if it still works. If the drive is dead then you need another drive.
2answers
Have a 1.5. TB "Sea gate Free Agent - Desk". Used
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
if your computer came with a motherboard disk the drivers could be on it
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
Hello, I just bought a Seagate Free Agent Go 1
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Recovered my pc,lost seagate manager somehow
Go to http://www.seagate.com/www/en-us/support/downloads/ and select your product then you can download any documentation and drivers that you need.
My Free Agent 1 TB external has been dropped a few times. It seems to be working fine, but it makes a lounder noise than it used to when accessing files. Should I worry?
Yes. If the case has been damaged, imagine what happened inside the hard disk, where the tolerances are in microns. Start saving for a new one.
2answers
I have a Seagate Free Agent Pro GB HD. Recently purchased a a new computer and cannot locate drivers for this equipment, can you recommend a site where I can download?
Hi and Welcome to Fixya,
Here is the download site from Seagate http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=freeagent-downloads&vgnextoid=3723b5b59b7d5110VgnVCM100000f5ee0a0aRCRD
Please check that link and then download the driver for your device.
Seagate 1 TB not detectable on win 2003, xp detects it
As you know,the Seagate sometimes has the firmware problems,so it seems that this firmware designed only valid in XP or Vista system,you may find the firmware update from the seagate official website
Win 98
You would need two set of driver:
  • motherboard USB drivers;
  • mass storage driver from Seagate for Win98.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Grand Canyon Tech
Grand Canyon Tech
