Has it been used offroad with Enduro wheels? Think you can re-set to road using the toogle button by the clutch. check the manual if you have one
Hi you are set on kilometers not mph speed adjust at switch
If the speedo gear is in the front wheel a different wheel would have different gear and mess up the speedo but I'm thinking the gear wouldn't mesh with the old speedo cable teeth.Check a shop manual for stock number of teeth on rear sprocket and tranny sprocket,that will tell the story.While your at it check the stock wheel size compared with what you got.Of course it could be bad speedo.There's springs in there that run needle, so?Maybe borrow one and try it out.Good luck.
If the battery has been disconnected,it may have been set for the supermoto when it was reconnected.Disconnect the battery,wait 5 minutes or so,then reconnect it,look at the speedo display and it will flash 'endr' or 'mtrd' alternately. When the display shows 'endr' (for enduro) press the blue mode button on the handlebar - problem solved - Simples !
Yes, it is used, i don`t know what previous work has been carried out on it.
Have you got a smaller front wheel fitted? this will cause a discrepancy.
Is the bike used?Maybe the previous owner changed sprockets and not the speedo gear that goes with it?
