The Pyramid PS-7KX is set at 5amp Constant, 7amp Surge. I want a quick, easy, cheap, way to make it 7amp Constant? I'm not "electronically" intelligent!
If your not "electronically intelligent" then where did you get the idea to make it 7amp constant? what would be your surge protection?If your not "electronically intelligent" then where did you get the idea to make it 7amp constant? what would be your surge protection?
You can't post conmments that contain an email address.
Check the pico fuses in front and behind the Convergences ICs STK392-110
Pico Fuses Look like resistors ,but they will be Yellow or Green 5amp -7amp fuses.
If they are Ok then you need to replace bopth ICs .
Mats Electronics has ICs 1-800-628-1118
Replace the Convergence ICs there is 2 of them Big black ICs they will have part number on them example STK392-110 .Also Check Pico Fuses in Front and back of ICs they look like resistors but are Green or Yellow 5amp, 6amp, or 7amp Fuses.
Mats Electronics has STK ICs 1-800-628-1118
Convergence ICs and CK all Pico Fuses around ICs they will look like resistors but will be Green or Yellow 5amp, 6amp, 7amp Fuses. Big Black ICs they will have the PN# on them
ICs STK392-110 use 120s Mats 1-800-628-1118
TV Repair Shop $255.00
Mats Electronics 1-800-628-1118
Make ure you CK pico Fuse around the STK ICs,
They are Yellow or Green and look like resistors but are Fuses 6amp 7amp 5amp,ect..
