Always after 15 seconds?? this sounds like thermal issue. if this is a custom build they often forget to apply proper amount of thermal paste to the processor causing it to not make good connectivity to the heat sink and thus not drawing enough heat away from the processor. a heat sink is used to actually increase the surface area of a processor. this in turn has a fan above sucking the air away from the processor. and another fan in the tower blowing the heat away from the case and out the back or side.
if you can get into bios. hitting the corresponding f keys when the system begins to boot but before windows starts to load.. you can see a screen called system health in bios. this will be or many not be present on the main page. entering it will give you temperature readings but be careful if proc overheats it will shutdown again in bios.and then you know you have to add thermal paste. temperatures will be in Celsius .id say anything in 80 degree Celsius range is rather hot. above 80 and id say your above the boiling point of water. and it needs to be looked at.
thermal take makes great cpu coolers if your aftermarket or oem cooler is failing. and it's very simple top replace following simple instructions.
Check your cpu fan first normally it's the fan.can give you more things to check, like memory stick but if that does not work write back and I can tell you also the power supply fan may be dirty or bad these are the most common thing you can find. and if you see a lot of dirt on the fan that is most likely your problem.
