means using wrong old and lame scan tools
p0700 means transmission error GENERAL( uSA fed code)
means others are there but not using 2008 or newer scan tools
means missing all those better DTC errors
get the car scanned in a real shop using real tools
no kidding.
Code 12 means that the battery input to the PCM was disconnected within the last 50 key cycles (this is a normal condition).
Code 55 means that you have reached the end of the codes. This is also normal
So if you have a 12, 55 code readout, you basically have no error codes stored.
Here is a link that lists the code sand what they mean.
okay, 1998 voyager these are not obd2 codes, these are genric codes, you used ignition to get these . these codes are for older models that use codes like these 12 35. the newwer obd 2 use codes like po 013. i will try to see what i can find, also the engine size is important.
okay here we go, the first code is 12, this code means the battery was dead or dissconnected. the next code 35. this code means loss of prime, code # 11 means internal transmission failure. the code 55 means gear ratio error.
these codes would tell me that you have transmission problems. this may mean internal trans failure and a rebuild or replacement transmission is needed or shift pack needs replacing. anyhow i would have a shop check this out, these van are known for transmission problems. hope this is helpful good day
Hi Rich Stuck,P0700 means Transmission Control System (MIL Request),P1684 means Battery Disconnected within last 50 starts.More read Diagnostic Trouble Code Table ,hope it can help you.
P0700 means transmission control fault detected,either it is mechanical or electrical.This code is a generic code,you will need a enhanced code that mean a manufacture scantool or a scan tool that can read enhance code.
