My Timex T276B alarm clock automatically updates itself for the time but it is always about 15 minutes behind. Is there some way to correct this?
SOURCE: operating instructions for timex t311t radio/alarm clock
Regarding how to set the time on a T311T Clock:
1. Push down the Time button and hold until number start flashing.
Push the right arrow until the time advances to the time desired.
2 To set the date, push the date button and hold until date starts flashing. Push the right arrow until the date advances to desired date
SOURCE: setting time and alarm clock for timex nature sounds clock
Hold the time set key in until the time flashes. Now let it go and use the tuning forward and back keys to set the time. I had the same problem because I continued to hold the timeSet button down while trying to adjust it. If you do, the forward/back keys have no effect.
SOURCE: Timex T158W Alarm Clock
Hold down the "buzzer", "radio" or "sound" buttons until you hear a beep and one of those words is blinking. then, use the arrow keys to go up and down by minute and only by minute (which means you are going to have to wait awhile if you want to change the time to many hours ahead or behind). When you get to the time you want, press enter.
SOURCE: Set Clock
This clock has 2 alarms to set Alarm 1, switch alarm 1 to the "set" position and make sure alarm 2 is pushed to the "off" "radio" or "cathedral" position, press and hold the "alarm" button on top while pressing the "f.fwd" or "rev" button to set the alarm....to set Alarm 2, do the opposite of the set buttons and repeat...to set the time just hold the time button down while pressing "f.fwd" or "rev"...hope that wasn't too confusing.
SOURCE: Timex T301B
Theres a manual for this online through Radioshack.
http://support.radioshack.com/manuals/ome12-1645.pdf
Press and hold the "Alarm
Set" button for five to seven seconds and the year will begin to blink when the clock is ready for
adjustment. .
Set the year by pressing the
right-arrow, "Up" or "+" button, depending on your model of
clock.
Set the month, day, hour and minute.
Press the "Alarm Set" or "DST" button to cycle through each
field, and use the "Up," "+" or right-arrow button to
adjust the values within each field.
Press the "Alarm
Set" or "DST" button after setting the date and time to store
the information into your clock's memory.
Press alarm 2 to change from Celsius to Fahrenheit.
Press alarm 1 to change from 24 hr time to 12 hr time.
