Question about Timex Audio Players & Recorders
How do I change the time on a Timex T235 Alarm clock - can't find my book
Posted by Pamela VonOlnhausen on
  • Timex Master
  • 6,259 Answers
To set the clock on the T235, make sure that the radio is off. If the radio is playing, press and hold the Power/Mode (the left-most button) until the display briefly shows Off and the time is displayed. Press and hold the Clock button (the center button), the display should start flashing. While the display is flashing, press the Tun + (Hour) button, next to the Power/Mode button, to advance the hour to the current hour. Then press the Tun - (Minute) button, between the Tun + and Clock buttons, to advance the time to the correct minutes. Then while the display is flashing, press Clock and hold to exit the time set mode. This will start the clock.
Timex has the manuals for many of their clock radios on the product page or their support page, https://timexaudio.com/support/ . For the T235, the direct link to the manual is https://timexaudio.com/media/uploads/product/files/T235_User_Manual.pdf . See page 6 to find the directions to set this model.
I hope this helps.
Posted on Nov 06, 2016
Turn Off alarm on T235 Timex Dual alarm clock
To disable the alarm, make sure that the radio is off. Then press the appropriate alarm button (ALM 1 or ALM 2 on the top of the clock at the right of the line of multiple buttons) repeatedly until neither the Buzzer or Radio indicators for that alarm are lit.
This is given in the manual on page 8. However, the detail about making sure that the radio is off is only in the sections about setting the alarm (page 4 and 6). The manual is available here: https://timexaudio.com/T235B/ . The direct link to the manual is currently https://timexaudio.com/media/uploads/product/files/T235_User_Manual.pdf . Note: the PDF is only one page; the page numbers are for small sections of the page in the mini-format manual that ships with the clock.
I hope this helps.
Nov 04, 2017 | Timex Audio Players & Recorders
T235 manaul
Go to manufacturer web site for manual download.
Dec 09, 2015 | Timex Auto-Set Dual Alarm Digital Clock...
Can I order a users manual from you for a timex alarm clock radio model T235
I don't know about ordering a replacement manual. I can point you to a copy available at Timex Audio's support page: http://timexaudio.com/support/ . Use the drop down menu to select T235 and you will be able to download the manual as a PDF. From there you can print the document or simply read it using Adobe Reader or a similar program.
The direct link to the manual is http://timexaudio.com/media/uploads/product/files/T235_User_Manual.pdf . You may be able to get a printed copy mailed to you if you call the Customer Support line (800-888-4491 between 8 AM and 4 PM EST M-F) or email them. If you want to email the support line, click on the "Contact Us" link on the support page listed above. Then click on the link for Email our support team.
I hope this helps.
Sep 26, 2015 | Timex Audio Players & Recorders
Timex number t235 clock radio, how do I set the time
easiest way to set clock time. Remove AA battery's if installed.
Unplug Clock from AC. Wait a few seconds. Then replug clock into AC power. Clock will now flash 12:00. Press hours button until correct time is set PM has led on AM has Led off. Set minutes to correct minutes. Then press alarm reset / power/mode button. Wait a few seconds and display will show correct time. Now you can put the AA batteries back in.
Apr 30, 2014 | Timex T065s Solar Powered- Radio...
I cannot change the time or the alarm AND I lost the book
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Many downloads here, find yours.
There are two ways to find the user manual for your Timex watch.
1. Find your watch on the list below and click on the language link for your manual.
2. Find the 3-digit module number located on the caseback of most Timex products and click on the corresponding language link for that number in the Module Table at the bottom of the page.
Mar 14, 2011 | Timex T309TT Clock Radio
Need instructions for stopping buzzer. Would like alarm to be radio.I have lost my instruction book. Model T311T.
press the top button on the right until the radio comes on, then set the alarm time.
Mar 15, 2010 | Timex (T307S) Clock Radio
How do i set the time on my timex clock? its the nature sounds alarm clock pleas help
press the time button and hold until the time starts to blink then use the < > to change the time then press Enter to set the time.
Nov 13, 2009 | Timex Nature Sounds LED Clock Radio
Turn off alarm buzzer completely on Timex T309
Press the Buzzer alarm button until its indicator on the LCD display goes out. This should defeat that alarm. For your interpretation:
Timex T309 Manual
Feb 07, 2009 | Timex T309TT Clock Radio
Daylight saving time auto change over
call 18006954820 they will walk you through
Nov 02, 2007 | Timex T276B Clock Radio
Timex T301B
Petewete,
Here is the manual.
http://www.timexaudio.com/pdf/T301IBOnline57204_83.pdf
Frank081541,
You can't adjust the Daylight Savings Time. I called Timex and they confirmed this.
Mar 06, 2007 | Timex Auto-Set Dual Alarm Digital Clock...
Top Timex Audio Players & Recorders Experts
efs_perpends
efs_perpends
Are you a Timex Audio Player and Recorder Expert? Answer questions, earn points and help others
