Gateway (4000779) Motherboard Logo
Posted on Mar 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need a driver for pulse jack ethernet controller jy0-0001
James Miller
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Gateway Master 2,226 Answers
  • Posted on Mar 24, 2010
James Miller
Gateway Master
Level 3:
Renaissance:
Answers
2226
Questions
0
Helped
447560
Points
2985
Go to web site gateway jim
I have a HP pavilion m8020n with Vista OS. I have internet for a while now and suddenly internet just went out. i talked to my internet carrier and we troubleshoot the connections. they said it might be...
2008 PC, shows it has modem too, a dial up. so 3 ways internet.
\there are 2 ways on to the internet (Ethernet and wifi)
aka, wired and wireless, respectively.
sure wifi router works,too, and is more difficult to setup. (im not going there)
try a new cable
try another router port yet, try cycling power only to the router?
sounds like your vista drivers are messed up ,
if another PC works , with ETHERNET cable to router there.then the router is working, test 1, passes.
that means this PC is failing
the PC has a control panel and device manager
see that and the network part? (not wifi , the wired network chip)]
vista 32b or vista 64bit?
your PC came with intel old
  • Interface: Integrated into motherboard
  • Technology: Intel 82562V
  • Data transfer speeds: up to 10/100Mb/s
  • Transmission standards:10-Base-T Ethernet
the driver is?
Intel 82562V
to make that chip work,
intel has it. 6 th down this list, Vista
https://downloadcenter.intel.com/product/76951/Intel-82562-Fast-Ethernet-Controller
load this driver. fixed. (from a working PC on the net)
then move it to dead pc and load it.
you are plugged in to X here. right.
or is there a card plugged in on the right, with RJ45 ethernet jack.
yes, you sure can add a new Ethernet card if the X jack blows out.
p5lple-fvyief5l4kybalhvncmspljg-3-0.jpg my DM ethernet port, im tying through it now...
mines a w10 gigalan port. so... is not intel like yours. ignore Realtek name pretend it says, Intel 82562V
I cannot connect to internet because my computer was remastered and trhe computer does not recognise my router and is telling me to install a driver
I Figure your using a USB lead from your router to your computer. You will need to download the USB interface driver from the Belkin web site. Otherwise, if the router has a ethernet jack, then use a patch cable to your computer (ethernet port) eliminating the need for a driver
Ethernet controller didn't work
Have you checked your drivers?
Go to control panel - system - device manager
Or control panel - type in device manager (depending on your os)
If there is a question mark beside your ethernet controller than you need to update the driver. If you have the disc pop it in the computer and then right click the ethernet controller and click update driver and then follow the wizard through and that should fix it if the driver isn't there.
If you haven't got the disc you will need to download the driver from the manufacturers site.
4helpful
How i istall ethernet driver from internet
If you have no internet because the ethernet controller was not installed, you will need to download the ethernet drivers from another computer.
To do this, you will need either the motherboard model or the ethernet controller model. Search google for your motherboard model, and then on the drivers page, find "LAN drivers". Download the drivers, save them to a usb and transfer and install them to your pc.
2helpful
I need a ethernet controller driver for xp so i can get on the web
There's a lot of Ethernet controller driver for xp on the web, please identify which one and model to provide the exact driver for your Windows XP.
2answers
Cant find ethernet driver
Try the program Driver Max. You can download it for free and update needed drivers.
2helpful
2answers
1helpful
4answers
Please, ethernet controller issues.
You need to re-install your Ethernet driver.If you have Driver CD with you then first uninstall the Ethernet driver from device manager and install the Ethernet driver from you driver CD.
If you don't have driver CD with you then You can download ethernet driver by Clicking here.
Thanks
7helpful
4answers
i need an ethernet controller driver for my dell dimension 4600 the operating system is windows xp home edition
Top Gateway Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
