Windows have stopped working
First check the fuses if you have not done so. You will need to remove the door panel to get to the driver side window switch, the power for all of the windows enters through the driver side switch. Use a multi meter to determine if power is reaching the switch, if it is not, run a temporary wire from the fuse panel to the switch and see if that will work the windows. If it now works you know the problem is a bad wire. If you are getting power to the switch but not power out the other side you know the switch is bad and must be replaced.
