20 Most Recent
Vornado VH2 Compact Heater Questions & Answers
My Vornado VH2 heater stops heating several
A big problem with these heaters ans well as others is the motor driving the fan. The bearings get stiff from dirt and do not spin fast enough activating the over temp device of the heating element. Check the motor out by placing the unit in fan mode them pull the plug or turn off looking at the fan to see how many revolutions is makes with no power applied. It should rotate like five times or more indicating freeness. If it hals to a stop immediately after power is removed the motor bearings are tight.
If your handy you take apart and oil the shafts using 3inone motor lube. Clean the motor of dust and dirt drop a few drops on the shafts near the bearings then work it in by hand rotating the blades. Do this a few times reassemble then ler ripp!!!
Does not turn on
This is a pretty common issue with these heaters. The switch can easily be replaced by opening the unit and swapping out the switch assembly. One switch I have found that works well and is reatively inexpensive (under $4) is the one from Radio Shack (P# 275-0020) which is a 16A 125VAC illuminated round rocker switch. Unlike the OEM one that drops in, the RS one is a panel type which you will have to screw into place. The whole procedure shouldn't take you more than 15min.
Static electricity
From what you have said, I am guessing that you shorted out the little controller chip(s) on the circuit board. Some of the Vornado heaters are serviceable by the company but you would have to check your model number. They have a live chat that can tell you if you go to Vornado.com and click on support you will see it.
