Sportsart 6300 Treadmill Logo
Posted on Mar 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sportart 6310 treadmill - check speed sensor
Sportart 6310 treadmill - err1 check speed sensor between motion and sensor board
Alma chee
Level 2:
New Friend:
  • Expert 69 Answers
  • Posted on May 28, 2015
Alma chee
Expert
Level 2:
New Friend:
Answers
69
Questions
0
Helped
81835
Points
161
This may be helpful: http://www.treadmillsrepair.co.uk/2014/04/speed-sensor-for-treadmill-error-e1.html
John Mazmanian
Level 3:
President:
  • Sportsart Master 832 Answers
  • Posted on Mar 13, 2010
John Mazmanian
Sportsart Master
Level 3:
President:
Answers
832
Questions
0
Helped
628636
Points
2056
Unplug unit and check the motor brushes they maybe worn and need to be replaced call Sports Art Fitness customer service @ 1-866-709-1750 they will sell you the brushes
1helpful
My Trotter treadmill shows err1 when I turn it on. What's wrong?
Hi There, Sounds like a speed sensor at first thought. Make sure any sensors are clean and working. If sensors look fine, with the unit powered off, check very carefully for any blown fuses on the lower board. Lastly, if the unit has been moved recently, be sure all connections are good at the upper and lower boards. Good Luck and you can contact buyfitnessrepairpartsDOTcom for more help on trotters.
How long does it take for someone to help me, on this site.
Hi. Hoping someone can help. I have a BH fitness pioneer classic model G6442C. It switches on fine but belt wont start turning and after few seconds “E1” error pops up. I have opened the box and tested and no power gets sent to the motor when you press start. “LED2” flashes once belt wont start. Any ideas anyone?
Sports art model 1050L give me err 1 how I can fix this problem? Thanks
Reason number 1:
Explanation for ERR1 1. Motor doesn't operate; ERR1 appears. 1-1. Explanation: Drive board has not sent power to the motor, so the motor doesn't operate; the optic sensor signal hasn't returned to the display board. This is caused by either a bad mcb or a faulty motor.
Reason number 2;
Reason for ERR1 2. Motor operates; ERR1 appears 2-1. Explanation: The motor operates; the optic sensor signal didn't reach the display board CPU; ERR 1 appears. In this case the issue is more than likely a faulty speed sensor or a there is dirt, lint or other debris blocking the speed sensor from reading the disc.
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Sports art model 1050L err 1 how fixed ?
Reason number 1:
Reason number 2;
E01 sports treadmill
This link is to the service manual. You will find error code definitions and troubleshooting flowcharts.
http://www.sportsmith.net/images/product_support/sportsart/Repair%20Manuals/General%20Treadmill%20Svc%20Manual.pdf
ERR1 Definition: The display board CPU didn't receive the optic sensor signal. • Explanation: After processing by the drive board, the optic sensor signal travels the 16-pin cable to the display board CPU, which determines motor speed. Components involved include the optic sensor, optic sensor wheel, 16-pin cable, drive board, display board, and connections.
Cybex 530t error 1
Error 1, Err1 Belt didn't start (or no speed sense) 1. Perform speed calibration procedure
2. Check speed sensor
3. Check motor brushes
4. Check drive motor
5. Check lower board
I am attaching a link for the service manual. This information can be found on page 65. You can use this manual to determine the steps required for checking the above mentioned items.
http://www.sportsmith.net/images/product_support/cybex/Manuals/Service/LT177304-CybexProPlusTreadmillOwnersServiceManual.pdf
Cybex Pro 530T Treadmill Parts Deck Belts Motor Rollers SPORTSMITH net
2answers
Displaying error 1 what could be wrong and how do I repair it?
Sportsart 1080 treadmill error 01
ERR1 Definition: The display board CPU didn't receive the optic sensor signal. • Explanation: After processing by the drive board, the optic sensor signal travels the 16-pin cable to the display board CPU, which determines motor speed. Components involved include the optic sensor, optic sensor wheel, 16-pin cable, drive board, display board, and connections. http://www.sportsmith.net/images/product_support/sportsart/Repair%20Manuals/General%20Treadmill%20Svc%20Manual.pdf
I have a Sportsart 1050l give's error 1?
ERR1 Condition: Press speed key; walk belt doesn't move; ERR1 appears. 1. Drive Board a) Inspect drive board components for signs of damage, like bulging, burnt or cracked spots. b) Inspect connections to the drive board, including the ribbon cable (at the display and drive boards), drive motor, incline motor, etc. loose connections are a common cause of ERR1. c) Check the drive board lED Turn on the unit. The should be lit. The EMG indicator should light up and then extinguish after the unit powers up. A lingering EMG light indicates drive circuit trouble, but it can also light up if drive board connections to motors and other components aren't secure. d) Test whether the drive board is sending power to the motor. Put the muttimeter to the DC setting. Disconnect the motor M+M- wires from the drive board. Place probes on the drive board M+ M- terminals. Put the treadmill safety key in place; turn on the power; walk on the treadmill so that the ClK lED lights (this preempts the display from detecting no optic sensor signaling and immediately giving you an ERR1 message, thus allowing you to get a power reading); press the speed up key. The meter should show some voltage. If there's no voltage, inspect the ribbon cable and display board. If they appear OK, suspect the drive board. e) Test drive board components for a short. See Components in the Basic Electronics. 2. Ribbon Cable a) Check the ribbon cable and its connections. Link a spare cable from the drive board to the display board, outside the unit. Test the unit. If it works with the spare cable, replace the original cable. b) Or, if you don't have a spare ribbon cable, test ribbon cable continuity. Wrap solder wire around each probe so you can insert probes into the ribbon cable connector, testing one wire at a time for continuity. 3. Display Board a) Press down on the display board ICs. If you have a working unit of the same kind, swap the display board onto this unit. Test. If all works well and no ERR message appears, replace the original display board. a) Reed Switch (Applies to models with magnetic safety keys only.) Put the safety key in place over the reed switch. Put the meter to the 200 Ohm setting. Place probes on both ends of the reed switch. Meter should show 0 Ohm. If the meter doesn't get a reading, replace the reed switch. 4. Treadmill Motor a) Rotate the motor. It should rotate smoothly. Grinding or sticking indicates wear. b) Check the motor brushes. Uneven wear indicates worn brushes. Minimum brush length: 1/2 inch. Turn the brushes around and reinsert them. Rotate the flywheel. If the motor grinds or sticks, put brushes back in their original position. c) Check motor resistance: Turn off unit. Disconnect the motor M+ M- cables from the drive board. Put multimeter setting to Ohms. Place probes into the motor wire M+ M- ends. Normal reading: 1 Ohm. Move the flywheel slightly and take another reading. Take a few readings, moving the flywheel slightly after each. Readings should be consistent. If the meter shows OL at any test point, replace the motor. 5. Transformer a) Put the meter to the AC setting. Place the meter probes on the transformer output wire connectors on the drive board. Turn on the unit. There should be output voltage. If not, replace the transformer. • 11XX/12XX brown-brown: 10.5VAC • 31 XXl32XXl61 XXl62XX white-white: 12.5 VAC • 6005 yellow-yellow: 11.0 VAC If ERR1 is not resolved, see ERR1 with walk belt movement. • • • • ERR1 Condition: Press speed key; walk belt moves; ERR1 appears. 1. Tachometer Wheel Make sure the tachometer wheel: a) Rotates in the middle of the optic sensor. b) Is clean and free of cobwebs and dust. c) Doesn't have broken or bent teeth. d) Is fastened securely on the motor bracket If the wheel has visible damage, replace it. 2. Optic Sensor Make sure that the optic sensor signal is getting to the drive board. a) With power on, turn the drive motor. The CLK indicator (an lED on the drive board) should light. This means that the optic sensor signal is reaching the drive board. If the ClK indicator doesn't light, replace the optic sensor. b) Push the treadmill belt while pushing speed up key. If ERR1 doesn't appear until you stop pushing the belt, and the display speed values increase, then the optic sensor is good. (On units without a ClK indicator, check optic sensor output voltage: (a) put probes on optic sensor output (b) turn the motor (c) if voltage doesn't vary, replace the optic sensor.) 3. Ribbon Cable a) Check the ribbon cable and its connections. Link a spare cable from the drive board to the display board, outside the unit. Test the unit. If it works with the spare cable, replace the original cable. b) Or, if you don't have a spare ribbon cable, test ribbon cable continuity. Wrap solder wire around each probe so you can insert probes into the ribbon cable connector, testing one wire at a time for continuity. 4. Drive Board Check whether drive board components are burnt or cracked. Check component connections. A drive board power component short usually results in a huge burst of power, making the walk belt speed dangerously, before ERR1 appears. If the walk belt moves before ERR1 appears, but not very, very fast, suspect the optic sensor. 5. Treadmill Motor a) Rotate the motor. It should rotate smoothly. Grinding or sticking indicates wear. b) Check motor resistance. Turn off unit. Disconnect the motor M+ M- cables from the drive board. Put multimeter setting to Ohms. Place probes into the motor cable M+ M- ends. Normal reading: 1-2 Ohm. If there's no reading (OL), replace the motor. c) Check the motor brushes. Uneven wear indicates worn brushes. Minimum brush length: 1/2 inch. Turn brushes around and reinsert them; rotate the flywheel by hand. If it rotates worse than before, put brushes back in their original position. d) High amp draw can indicate a bad motor. Other factors would be a worn walk belt and deck. Run unit power through a current meter. Tum on the unit. Normal amp draw at 3 MPH with no load on the walk belt is 1/2 to 1 Amp. 6. Display Board ICs Make sure that IC contacts on the display board are good. Press firmly on the ICs. Make sure you have the latest CPU version. If ERR1 is not resolved, see ERR1 no walk belt movement.
Treadmill Parts for SportsArt Belts Motor Brushes SPORTSMITH net
Err1 error message, york aspire treadmill
ERR 1 - Motor Movement
ERR1 indicates a speed issue. In this case, the motor speed as reported from the optic sensor differs
from the speed setting.
Analysis: Optic sensor signal issue -- Either the optic sensor signal is not right, or it is read incorrectly, or
the signal is not reaching the display.
Clean the sensor, test for open or faulty, tight the connector very well,adjust it, see the diagram attached.
God bless you
Top Sportsart Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
john h
ADMIN Andrew
ADMIN Andrew
Are you a Sportsart Exercise and Fitnes Expert? Answer questions, earn points and help others
