Thank you for posting your question here on Fixya.com.
You can not repair those small submersible pumps. Let me rephrase that...you should not try to rebuild those pumps. Once the oil leaks out and water enters the sealed motor area causing the unit to seize you can not replace the parts you will need for anything close to the cost of just buying a new unit. They are basically throw-away units at the price of new being under $100.
Home Depot for $62.97
Lowe’s 1/3HP ProPlumber
Local hardware stores will have similar products for nearly the same prices.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Testimonial: "Thanks! That was a big help "
