SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
I tried all that my sd card still will read card protected do I have a bad card?
SOURCE: the camera says protected card
depending on the type of card you should see a little slide or something that you can move and in one direction it will say lock or something of that sort and if you slide it away from that position that should fix your problem. good luck!
SOURCE: The Camera is saying "protected
Just solved by looking at the memory card itself......there's a switch on the actually memory card......click it & then put it back in the camera!!!!
